Old 05-21-2014, 01:15 PM   #141
FRSupra
FRSupra's Avatar
@regal you should read the 86 Development story so we don't have to hear you cry about D4-S anymore.
FRSupra is offline   Reply With Quote
The Following 2 Users Say Thank You to FRSupra For This Useful Post:
Jond63 (05-22-2014), Mikem53 (05-21-2014)
Old 05-21-2014, 01:19 PM   #142
Mikem53
Drives: FR-S 6MT
Originally Posted by regal View Post
I still am stuck in the 80's early 90's but the rest of the world isn't DIT is magical if you ever get a chance drive the new Cayman and ask yourself why did TADA killed Subaru's brilliant FA20T for our car. With mass production of that engine in the forester and wrx and dropping D4-s it wouldn't have added any real cost if they tuned it for not too much torque. Its a shame really but as you say no car is prefect and hopefully going NA will mean longer term reliability which is more important to me. Also heads up Mike53 doesn't like plus's/minus's posts so have that flame suit ready
Lol.. Again.. You keep saying it should have had the turbo, Tada messed up..etc.
I did drive a cayman and for only 35k more I could have had one. The cayman isn't a turbo so how can you compare it to the twins.. Nor is it anywhere priced similarly. So what's your point? You think Tada should have given us Cayman performance and power all for $25K ? Well that would have been nice and I think all would agree.. But in the real world, Tada did great for what he had to work with!
You bought the wrong car, it's NA and thanks the the D4S, it is able to have a NA power plant with adequate power for its price point.
No flame suit required here.. Just a bit of common sense.
I'm curious.. Didn't you test drive the car BEFORE you bought it.. That's really important you know...
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
chas3wba0 (05-21-2014)
Old 05-21-2014, 02:44 PM   #143
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I'm not trying to spark anymore flames here, but a decade ago Honda provided the K20 motor, a non-D4S type of 2.0 litre NA engine pushing 205 hp.
To only be able to get 200hp out of the new Boxer engine in 2013 with the 'help' of D4S is really sad compared to what Honda did a decade ago. Perhaps a flat four has less potential than an i4, I'm not engineered to know this kind of stuff so.....
However, if the car can make 250hp NA + D4S in this decade that would be something to talk about.
LeeMaster is offline   Reply With Quote
Old 05-21-2014, 04:11 PM   #144
misooscar
misooscar's Avatar
Drives:
I think it's great because of the low cost of entry.
Sent from my SM-N900T using Tapatalk
misooscar is offline   Reply With Quote
The Following User Says Thank You to misooscar For This Useful Post:
xxBrun0xx (05-22-2014)
Old 05-21-2014, 06:29 PM   #145
Jegan_V
Drives: 2023 Subaru BRZ
Making a high output engine out of a 2.0L isn't too difficult, heck the previous Celica GT-S's 2ZZ-GE achieved 180 hp out of 1.8L without direct injection. The difference however is the K20 and 2ZZ-GE was developed at a time when emissions regulations are much more lax. Fast forward 10-15 years, they're far more stricter hence why so many turbocharged engines suddenly are showing up in mainstream cars. Lotus would still be using the old 2ZZ-GE engine...but its failing modern emissions and as a result they had to drop it. Going with direct injection is currently the easiest way to increase power while at the same time reducing an engine's emissions. Why do emissions matter to a automaker or owner? In some countries its actually taxed, this is why some American cars like the Mustang simply avoid those countries(for the 2015 Mustang only the 2.3L Ecoboost will be available to world markets) or in the case of Chevrolet and its Camaro...it turns a affordable car...into a more expensive car.
Jegan_V is offline   Reply With Quote
The Following 2 Users Say Thank You to Jegan_V For This Useful Post:
litemup (07-14-2014), strat61caster (05-22-2014)
Old 05-21-2014, 06:54 PM   #146
fatoni
dont forget the use of multiple cam profiles. thats a pretty big deal if you ask me.
Old 05-22-2014, 01:00 AM   #147
Jond63
Jond63's Avatar
Drives: FR-S Firestorm 2013
At 2Krpm this D4S puts out more torque than my '02 S2000 did at 7krpm. And around town about 7mpg better. I like it.
Oh, and I want to add that 14 years later the FR-S is $4k less than the S2000, and for me a much more enjoyable all-around drive. Yes, it's built a little cheaper, but still great AND it has a roof!!
Jond63 is offline   Reply With Quote
The Following 3 Users Say Thank You to Jond63 For This Useful Post:
Mikem53 (05-22-2014), Quentin (05-25-2014), strat61caster (05-22-2014)
Old 05-22-2014, 09:17 AM   #148
neutral
Drifter-Wannabe
Drives: Firestorm MT FR-S
Send a message via AIM to neutral
That Nino video review is what put me over the edge to buy the FR-S. 2 years later, no regrets.
neutral is offline   Reply With Quote
Old 05-22-2014, 09:33 AM   #149
DarkSunrise
DarkSunrise's Avatar
Yep that's the key. Older engines (Honda's K20 and F20, in particular) made 100+ hp/L using variable lift cam profiles. Lower torque in the lower rpms, but the trade-off was an engine that could maintain torque to 9000 rpm thanks to the higher lift cam profiles.
The FA20 lacks variable lift, but uses direct injection, which gives it the ability to run a higher compression ratio without constant detonation (12.5 vs. 11.0 for the F20/K20). This basically means more torque, but also an engine that won't breathe as well past 7400 rpm due to the lack of variable lift cam profiles.
You can see the difference in respective approaches in this f20 vs. fa20 dyno:
Subaru/Toyota were pretty much forced to go this route because of emissions and fuel economy standards. That's pretty much what killed off those older Honda's engines and what makes them irrelevant for purposes of comparing engines today.
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
FRSupra (05-22-2014), Quentin (05-25-2014)
Old 05-22-2014, 10:05 AM   #150
fang_gt86
FR Noob
fang_gt86's Avatar
Combine both systems and we'll have a superior 2.0 NA engine? Can you imagine an FA with D-4S and Vtec....
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 05-22-2014, 10:12 AM   #151
DarkSunrise
Haha I do wonder how much power Honda's F20 could have made with DI and 12.5 CR. I would guess 260 hp with a fatter torque curve.
But would still have the same emissions/fuel economy issues, so we'll probably never know as Honda won't build it.
2022 BRZ Build
2013 FR-S Build
Old 05-22-2014, 10:30 AM   #152
cy1clown
As to the original question here are my answers in order of importance;
1. rear wheel drive
2. distinctive styling
3. fun to drive
4. decent gas mileage
5. reasonable price
6. not a convertible
What other new car hits all these points?
Thanks
Jon
cy1clown is offline   Reply With Quote
Old 05-22-2014, 10:36 AM   #153
ayau
Drives: Some rust bucket
1. rear wheel drive
3. fun to drive
5. reasonable price
Thanks
Jon
Hyundai Genesis, 350Z/370Z, Mustang, RX8.
RX8 is probably the closest to the twins.
Old 05-22-2014, 01:54 PM   #154
FRSupra
FRSupra's Avatar
To give credit where it's due, the vtec system in the s2k was designed to show power high end. Like said above, the power comes close to redline.
I'm going to disagree here. I'd say the Elise, followed by the gen 2 MR2, then the s2000/Miata. I know, mid engine and convertible...
WA Perth AUSTRALIA Toyota 86 GT86 Silver. Great condition inside and out. Avail now! ysagisan Cars for Sale/Trade 0 11-27-2013 10:12 PM
New set of Toyota FT-86 interior photos from the studio (some great details) Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 09-15-2013 01:29 PM
Great Experience at Cabe Toyota in Long Beach, CA HotLeopardMama Dealer Cars 0 06-04-2012 02:27 PM
Autocar Scans: Toyota 86 First Drive Review and Recap of Great Japanese Coupes Boxer-4 Scion FR-S / Toyota 86 GT86 General Forum 5 11-30-2011 06:23 PM
