Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
05-23-2017, 08:21 PM | #1 |
Drives: 2014 FR-S
How to get rid of rust spot?
I have a minor rust spot on my roof that I would like to get rid of before it spreads.
I spent 5minutes on Google and apparently I have to sand it down to the metal and repaint it. I do have some touch up paint, so that would be an option. Does anyone have tips or just any insights on getting rid of the rust? I can't get the image to work, so here's the link. http://imgur.com/a/EtMCW |
05-23-2017, 08:55 PM | #2 |
In the picture it looks like the rust has already spread under the paint on both sides of the chip. You will have to remove the bubbled paint then clean. A Dremel tool will work well, for DIY a rust converter instead of a normal primer works well, then paint.
05-23-2017, 10:01 PM | #3 |
Feeling like thinking....
Get the starter package of POR15 products. Nothing else will stop rust. You'll need to paint over it and it'll take some work to get your touched up spot to blend seamlessly (an impossibility in my experience, but I stink at body work), but when faced with a choice between a near-perfect finish with the almost certainty of returning and increasing rust, or an imperfect job with rust pretty much eradicated permanently.. well... I'll take the cure over the bandaid any day.
Drive like everyone's life around you depends on it...
05-24-2017, 06:35 AM | #4 | |
Just sand it and coat it and all will be fine.
05-24-2017, 07:42 AM | #5 |
Drives: 2014 FR-S
Thank you, I'll try that. How long would I have to do this? Obviously the longer I wait, the worst it gets, but I may be unable to do this until the weekend if the weather does not behave. It should not be too late, correct?
05-24-2017, 07:48 AM | #6 | |
There's a reason body work shops, at least in our area, will not warranty any work done on rust. POR15 is the only stuff I've found that will stop it. I live in the Lake Ontario lake effect snow belt (actually, just slightly below the worst of it, but we still get hit a LOT) and they use a TON of salt here. Maybe it's not quite as bad, salt-use-wise, up where you are, T, and that could explain our different experiences. If your area DOES use a lot of salt, too, then I'm not sure how else to explain my bad luck with rust compared to your experiences. If I recall correctly, I don't think either one of us are particularly diligent when it comes to washing our cars... Yes, modern cars do MUCH better with rust prevention than cars did a few decades ago.
The Following User Says Thank You to MuseChaser For This Useful Post: | Tcoat (05-24-2017) |
05-24-2017, 07:57 AM | #7 | |
The Following User Says Thank You to Tcoat For This Useful Post: | MuseChaser (05-24-2017) |
05-24-2017, 02:43 PM | #8 |
The sooner the better, but a day or two will not matter.
I agree with Tcoat, I have many fixes that have lasted as I work primarily on old cars. Preparation and cleanliness is key to getting good results. Usually not being aggressive enough in preparation is the problem. We want to think that the less we sand the better and will leave an untouched ring around the edge is ok, not so. POR-15 is just one of the many good converters. |
05-25-2017, 07:17 AM | #9 |
Drives: 2014 FR-S
Thanks guys, I did grind it down to the metal, used a rust converter and painted over it. It turned out to be a bit wider than I expected it to be, but it's better than having the car rust down.
The paint isn't uniform and it's slightly off-color. It's not very noticeable unless you are close up or looking for it. Thanks to you guys I don't have to burn it with fire. |
The Following User Says Thank You to Yousend For This Useful Post: | Tcoat (05-25-2017) |
05-25-2017, 12:23 PM | #10 | |
Drives: '17 86
05-25-2017, 12:55 PM | #11 |
Drives: 2014 FR-S
For sure, I forgot to do that last night. I had other stuff to do immediately after the process so I never got around to it. I've seen my fair share of body work threads to know that before-during-after pictures are necessary!
I'll edit this post once I get back home in a couple of hours. |
The Following User Says Thank You to Yousend For This Useful Post: | cat94 (05-25-2017) |
05-25-2017, 06:36 PM | #12 |
Drives: 2014 FR-S
After grinding it down
Close up A bit further out Not the best lighting, but I was too lazy to move it at that point. Now I only have a minor issue, I guess I put too much rust converter/didn't clean it up well enough that makes it super obvious. There's a brown spot around my new paint job! I assume that'll go away the moment I clean it properly? |
05-25-2017, 06:53 PM | #13 |
Drives: Grrrr
Looks OK. Man on a flying horse isn't going to notice that.
The Following User Says Thank You to Scrappydoo For This Useful Post: | Tcoat (05-25-2017) |
05-25-2017, 07:16 PM | #14 | |
Similar Threads | ||||
PSA: Beware this rust spot | headlikeahole | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-01-2015 06:36 PM |
Can you spot the BRZ or GT86? | hanabie | BRZ First-Gen (2012+) -- General Topics | 11 | 08-23-2013 07:08 PM |
Small rust spot look a like stain? | Bach415 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 23 | 04-30-2013 01:35 PM |
Rust? even with rust proofing? | Chinadian | Issues | Warranty | Recalls / TSB | 8 | 01-26-2013 04:15 PM |
New Parking Spot | raul | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 09-05-2012 12:42 AM |
