Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-29-2013, 08:05 PM | #1 |
BAMF
running lean
I'm running a catless header and I've been throwing a code p2096, post catalyst fuel trim system too lean bank 1. Any idea of risks for this? I know if its too lean I can blow my motor so I don't want any smart ass answers. I'm looking for actual technical discussion as to what is actually too lean and I will provide logs of Afr commanded and measured with corresponding rpm. Is there anything else I should be logging like load or anything else?
07-29-2013, 08:17 PM | #2 |
Did you run any sort of oxygen sensor spacer? I ran into this code too. So I took the spacer out and got po420 code. Long story short: watch your fuel trims. As long as you are +/- 5% from 0 you are fine. However CEL will affect you traction control systems. So spending time with spacers and washers to get the perfect spot in between where you will get lean code from being too far out, or p0420 code from being too close I've got over 7k on my Catless header with no ill effects and fuel trims +\- 5%
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
07-29-2013, 08:28 PM | #3 | |
BAMF
07-29-2013, 09:06 PM | #4 |
Drives: Sterling BRZ Ltd
Basic question, is the car tuned for no cats?
07-29-2013, 09:08 PM | #5 |
BAMF
07-29-2013, 09:27 PM | #6 |
Drives: car
ECU is not getting an expected rear o2 sensor reading because of the catless header.
The rear o2 sensor is used for the catalyst monitor (which most people are aware of) but it's also used to adjust the reading of the front o2 sensor in cruise operation. It accounts for degradation in the front o2 sensor. |
07-29-2013, 10:01 PM | #7 | |
BAMF
07-29-2013, 10:37 PM | #8 | |
Drives: 2013 Asphalt FR-S
The lean code probably indicates sensor 2 is a bit too far from the stream of exhaust gas or has too small of an opening.
~Namaste~ |
The Following User Says Thank You to mad_sb For This Useful Post: | EZWood (07-30-2013) |
07-30-2013, 12:29 PM | #9 | |
BAMF
The Following User Says Thank You to EZWood For This Useful Post: | mad_sb (07-31-2013) |
07-31-2013, 08:32 AM | #10 |
or cat inefficiency code P0420. Vibrant sells one you can tweak, it has 3 different orifice inserts IIRC.
~Namaste~ |
07-31-2013, 02:26 PM | #11 |
Drives: Toyota 86
How long were you running the spacer before the code first came up? I've been running an angled o2 sensor on my Borla UEL header for 2,000km now. 2 track days and a lot of highway running with the cruise control on, no CEL so far.
07-31-2013, 02:44 PM | #12 |
BAMF
It comes on pretty quick. Could you post a pic of how yours is mounted please?
07-31-2013, 03:09 PM | #13 |
Drives: Toyota 86
07-31-2013, 05:21 PM | #14 |
BAMF
Similar Threads | ||||
RPM dip with A/C running | BunnyRZed | Issues | Warranty | Recalls / TSB | 31 | 10-22-2014 09:56 PM |
FA20 Fuel lean at high boost fix | cf6mech | Forced Induction | 15 | 05-20-2013 03:33 PM |
Running low on gas | Arctek83 | Scion FR-S / Toyota 86 GT86 General Forum | 63 | 04-15-2013 07:35 PM |
Slip+CEL = Bank1 running lean? | Trashed675 | Issues | Warranty | Recalls / TSB | 11 | 03-28-2013 10:53 PM |
Running 19's | SocalBurt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-04-2012 02:45 PM |
