04-19-2017, 02:26 AM | #1 |
Drives: 2013 FRS - Ultramarine
REMOVING 3m tape from car
So i used 3m double sided tape to install my spoiler on my frs. and now i want to take it off becuase im going back to the stock look. any suggestions on how to do this without messing up the paint?
2013 ULTRAMARINE FR-S
04-19-2017, 03:25 AM | #2 |
Drives: BRZ Limited; GR86
use a heat gun to heat up the tape. then you should be able to remove the spoiler and the tape residue
The Following 2 Users Say Thank You to shaynek For This Useful Post: | e_lunatic (04-19-2017), ry_zillafrs (04-19-2017) |
04-19-2017, 04:12 AM | #3 |
Drives: JRSC'd Asphalt FR-S
Leave it out in the sun, get some fishing line and saw away. helps to have an extra hand to help lift the spoiler. then lots of goo gone to clean up. good luck
04-19-2017, 04:23 AM | #4 |
BAE
Drives: Asphalt FRS
Lots of goo gone and time.
04-19-2017, 03:00 PM | #6 |
Drives: 4 wheels
Pekingduck's Build thread http://www.ft86club.com/forums/showthread.php?t=5717
04-19-2017, 05:15 PM | #7 |
Feeling like thinking....
You'd be amazed at how good WD40 is at cleaning off adhesive residue of any kind. As a lubricant, it's awful... as a cleaner, it rules.
Drive like everyone's life around you depends on it...
The Following User Says Thank You to MuseChaser For This Useful Post: | Chronology (04-19-2017) |
04-19-2017, 06:00 PM | #8 | |
Drives: 13' Satin White Pearl BRZ
1. Heat the area 2. Use fishing line as a knife to remove what you can 3. Soak in WD40 4. Get your Friday night rub on 5. Clean area with water + detail spray of your choice and you should be good to go.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
The Following 2 Users Say Thank You to Chronology For This Useful Post: | e_lunatic (04-20-2017), ry_zillafrs (04-20-2017) |
04-20-2017, 01:48 AM | #9 |
thanks everyone!!!!!!!!!!!!!!
04-20-2017, 11:37 PM | #10 |
Drives:
Try rubbing alcohol. Works for tape adhesive.
Similar Threads | ||||
Trakk Tape | Black Tire | Tracking / Autocross / HPDE / Drifting | 10 | 05-15-2017 05:03 PM |
3M tape for TRD JP parts? | MisterSheep | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 02-25-2017 10:36 PM |
Is that...grip tape? | Firejetmanguy | Scion FR-S / Toyota 86 GT86 General Forum | 56 | 04-13-2015 05:18 PM |
3M Tape | ThatManAnt | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 07-18-2014 07:28 PM |
which 3m tape is this? | mokinbird87 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-29-2013 09:12 PM |
