Old 10-27-2013, 01:03 PM   #1
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
OEM coolant part #'s
Hey guys,
My coolant level is below the "low" mark on the overflow tank, so I figured I'll pick up a gallon and top it off. After doing some searching around the forum, I found a few conflicting part numbers, so I just wanted to know if anyone can confirm my assumptions or correct me if I'm wrong. It seems like both of these coolant types are the same, but the toyota stuff is ~$10 more.
Here's the conclusion I came to:
Toyota p/n: 00272-GTBC1
Subaru p/n: SOA868V9270
So, are these the correct coolant part numbers for our cars?
Thank you!
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 10-28-2013, 09:29 PM   #2
SportInjected
Anyone?
'13 Argento FR-S
Old 10-28-2013, 09:38 PM   #3
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Distilled water
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-29-2013, 12:12 AM   #4
SportInjected
Originally Posted by tonystewart View Post
Distilled water
I'm afraid this won't cut it in the midwest winter, which is quickly approaching. I'd like to maintain the 50/50 mixture to be on the safe side.
'13 Argento FR-S
Old 10-29-2013, 04:06 AM   #5
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
Drives: FG1 Civic,NA Miata, Whiteout FRS MT
00272-GTBC1 is the toyota version, so yes you're right
CyberAkuma is offline   Reply With Quote
The Following User Says Thank You to CyberAkuma For This Useful Post:
SportInjected (10-29-2013)
Old 10-29-2013, 08:57 AM   #6
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by SportInjected View Post
Hey guys,
Thank you!
Yes, right on both.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 10-29-2013, 08:28 PM   #7
SportInjected
Great, thank you gentlemen!
'13 Argento FR-S
The Following 2 Users Say Thank You to SportInjected For This Useful Post:
CyberAkuma (10-29-2013), Sportsguy83 (10-29-2013)
Old 10-29-2013, 11:39 PM   #8
CyberAkuma
OOH KILL EM
CyberAkuma's Avatar
You're welcome but before you make your purchase please take a look at this thread
http://www.ft86club.com/forums/showthread.php?t=26482
Originally Posted by ahausheer View Post
Coolant expands as it warms up and contracts as it cools, so you need to specify when each measurement was taken. Also, make sure the car is level. If you actually are loosing coolant that is not normal or a good thing. There is another thread asking essentially the same question, you may try to search for that. If you are truly loosing coolant there are only three possibilities. Its dripping/leaking due to a loose hose or connection (not to bad), its boiling-over and literally overflowing from the reservoir (not good, could be worse), or it is getting into the combustion chamber and being expelled in the exhaust (very bad).
SportInjected (10-30-2013)
Old 12-29-2013, 02:27 PM   #9
fareastbrz
Drives: WR Blue BRZ
so i'm guessing for the non 50/50 just coolant and antifreeze.
PN: SOA868V9210?
fareastbrz is offline   Reply With Quote
Old 12-30-2013, 09:51 AM   #10
frslee
Just drive it
Drives: 13' FR-S
Isn't the bottle already 50/50 mixed? I just topped it off.
From Toyota, the description on back specifies "FR-S Engine Only"
From Subaru, the super blue coolant.
Either one is fine.
frslee is offline   Reply With Quote
Old 01-01-2014, 06:40 PM   #11
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
The Superblue is already a 50/50 so don't add water to it.
-mike
AZP Installs is offline   Reply With Quote
Old 09-19-2017, 04:45 AM   #12
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Glad I found this thread, this is the one I'm about to purchase. Not trying to do what I do for my daily by going to Advance Auto for it.
https://www.amazon.com/Genuine-Subar.../dp/B007NLOZAU
rookietopro_frs is offline   Reply With Quote
Old 09-19-2017, 02:07 PM   #13
stevesnj
stevesnj's Avatar
PENTOFROST A3 at Autozone is the same stuff if not the supplier for the Subaru OEM coolant.
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
venturaII (09-22-2017)
Coolant Disappearing civicdrivr Issues | Warranty | Recalls / TSB 313 05-18-2016 09:56 PM
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 06:34 AM
Adding Coolant JLMtm Scion FR-S / Toyota 86 GT86 General Forum 5 05-11-2013 07:03 AM
Coolant Levels DriftEightSix AUSTRALIA 17 01-29-2013 09:19 AM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 12:03 PM
