FR-S / BRZ vs.... Area to discuss the FR-S/BRZ against its competitors [NO STREET RACING] |
07-09-2012, 10:37 AM | #113 |
head of infinite swagger
Drives: 2013 FR-S 6MT
I have an e46 M3 and i have to say that it's an amazing car, I have basic mods: coilovers, swaybars, intake, axle back.
I've been considering getting something a little newer and the FR-S has really caught my eye as a cheap no non-sense sports car The M3 is a fantastic car, not the fastest in a world of 420hp hp mustangs but definitely still fast enough to get you in trouble. The biggest thing everyone always says is that maintenance will kill you, and that's a half truth. There are some very expensive services that need to be done, but not that often. It works like oil change -> oil chance -> major service. The major service can run you anywhere from $1500-3000 depending on where you go however it's quite extensive and requires that they keep the car for the day or even overnight as they're changing most of the fluids in the car. The oil is also very very expensive, but i only change it once a year (more often than the car actually requires) so it's not the end of the world. The big problem is when something breaks (especially anything engine or transmission related) out of warranty and you're looking at serious dollars. You should have a good mechanic that you trust,Ii do and luckily i've been spared any major repairs since i've owned the car (only an alternator so far). Luckily it is by all accounts a relatively bulletproof car if you keep up the maintenance. How does this car stack up to the very brief autocross drive of an FR-S I've had? They're completely different. The M3 is way heavier, although much more powerful and easier to take sideways. Turn in on the FR-S is crisper and more urgent (despite the suspension work on the M3), the transitions in the FR-S were faster and easier to make, and overall the car just felt lighter on it's feet. The M3 is still an amazing driver's car though, on some twisty back roads with the engine singing above 6000rpm is the closest i've been to driving nirvana in my admittedly short life. The interior on the FR-S leaves a lot to be desired compared to the M3 unfortunately, despite being much older my M3 has options you still cant even get on an FR-S like backup sensors, memory seats, motion activated alarms, 10 way power heated seats, etc. You are definitely losing out on some luxury with the FR-S. The M3 also has a useable back seat, I'm 6' 180lbs and my 6' 225lbs friend can sit behind me and has enough leg and head room to be comfortable, that will never happen in an FR-S. My M3, 2004 alpine white 6 speed manual: |
The Following User Says Thank You to f0rge For This Useful Post: | D4ng3r (07-10-2012) |
07-10-2012, 05:12 AM | #114 | |
Drives: 2 legs and a beating heart
I would buy it from you in a heartbeat if you decided to move to an FR-S <3 |
07-10-2012, 11:28 AM | #115 | |
I would say on average it's $1000ish maintenance a year, although you'll want some money in the bank in case anything goes wrong, replacing tires after the trailing arm bushings killed them was expensive, replacing the alternator was ~$600, etc... Doing an inspection service, alternator and rear brakes in 1 year was hugely expensive for example. You just have to realise that everything you do is going to be more expensive because it's a premium brand, and for that reason all parts and service are more expensive. If you're used to Chevy/Honda pricing on parts/labours/mods then be prepared to be shocked when you enter into a world where a nice axle back exhaust costs $2200 and a supercharger is $14,000. If I wasnt in Canada and you weren't in China I would take you up on that offer, it'll probably be up for sale in the next couple of months, I'm looking to downsize to 1 car and the GF is too afraid to drive the M3 for some reason. |
07-10-2012, 11:31 AM | #116 |
Drives: ~_~
One of my favorite cars from BMW:
E46 and E92 Anyways, at least here dealer maintence is hella expensive on the E46, as I heard it is quite also high cost to maintain. Go figure for a race car
Join us! @ EightSixClub |
07-10-2012, 03:25 PM | #117 |
Some of these prices seem a bit high for the E46 M3's maintenance. More realistic numbers are:
Oil change every 15k miles: $160 from a dealer. Typical oil change is what, $60-70 for good synthetic every 7k miles? So you're not spending much more in oil and you worry about it less often. 18" 225/45 and 255/40 tires: $700 to 1200 installed, depending on the tire. 19's expect to add another $200. If something major fails on an SMG car it will likely be a component of the SMG transmission, such as a pump or relay. If it's a relay you're out $10, if it's a pump you might be looking at $1500. The percentage of M3's with SMG related issues is far less than the internet leads you to believe. You're more likely to over rev an engine and pop it with the manual transmission car. Money shift anyone? Can't happen with the SMG. Rear subframe tearing. If it's caught early you may be looking at a little over $1k. Again much less common than the internet leads you to believe. Window motors ($40), sunroof track guides (plastic $5 clips), control arm bushings ($60-100) are much more common issues. I personally love my SMG M3, especially in the DC area with tons of stop and go traffic. Then on the back roads it roars like no other sub 350hp car can. Plus if you have $2k to spare and don't mind giving up a few luxuries, not comforts, you could get an E46 M3 near the 31XX lb range. Now for my comparison to real-world experience with the FRS: A good friend of mine just picked up a FRS (you can read about it on http://www.rightfootdown.com/?p=1903 ). We hit the back roads a few weeks ago and damn did it feel nimble. It felt light on it's toes and inputs were instantaneous. The tires were horrible. When driven hard the front end felt it was on the verge of washing out or the rear end was wanted to say hi to the headlights. The engine wasn't necessarily under powered, but certainly was not going to thrill anybody on straight tarmac. The most enjoyable parts of the car were most definitely the response, driving position, and being able to put the right foot down way earlier than most cars when exiting a corner. If I had a BRZ or FRS the first thing I would do is replace those forsaken tires. For me, I am considering an FRS or BRZ for the fun factor and fuel economy. Mainly the fuel economy, because to me, the E46 M3 is way more of a hoot driven full bore than the FRS or BRZ will ever be. How often do I drive full bore? Perhaps not nearly enough to warrant 333hp over 33MPG. Ideally you'll drive both cars and reach your own conclusion. |
07-11-2012, 09:41 AM | #118 | |
I'm also running 245/35-19 and 275/30-19 tires and again for some reason tires cost more in Canada than the States. |
07-13-2012, 03:40 PM | #119 |
Drives: E46 M3
I've had my M3 2.5 years now and the only broken part has been my window regulator which cost me $240 to have repaired. I've spent about $1000 in maintenance including valve adjustment, preventive cam bolt replacement and oil/fluid changes. They aren't as scary as forums make them out to be then again I picked up a well sorted low mileage car and not some trashed put away wet wreck. Looking at BRZ for a possible second car.
07-13-2012, 06:43 PM | #120 |
Drives: Toyota Tacoma
I have an 05 zhp and it is a blast to DD. Unparalleled performance and can seat 4 adults just fine.
Tires are expensive Premium gas @ 19mpg. Oil change $100 Rtabs $100 Valve adjustment $300 Salmon relay $6 (Luck of the draw) possible failures: Vanos $2000 Window regulator $60 Water pump $600 Hid ballast igniter $50 Smg issues $2000 You need 2k in the bank for emergency funds. I am considering an frs for a fun car because toyota/subie parts would be cheaper and have overall lower maint costs. I am scared to track the m3 for fear of expensive repairs. I think e46 m3 looks awesome. Turn dsc off. Sport mode on. S6...party time! Not sure why people dont like the raspy noise? Revving to 8k is heaven to the ears. Only problem is you end up going way faster than you realize... I am a toyota fan boy and have been waiting for this car forever. Wanted an affordable reliable fun performance car to learn how to drive and drift. Bottom line is with european cars, you will never have the peace of mind that your car will never crap out on you. My friends 03 m3 crapped out on the freeway a couple of times. I know this will happen to me someday also but i have AAA lol. With more electronics comes more problems. My 89 corolla never died no matter what and my tacoma will alway get me home at the end of the day. Then again 142hp toyotas never made me grin the way 333hp does. You decide. |
07-15-2012, 05:08 AM | #121 | |
Balance over power...
Drives: 13 Hot Lava Frs, 88 Supra Turbo
07-15-2012, 05:11 AM | #122 |
You and damn near all of us will but we know that aint happening...
07-15-2012, 05:25 AM | #123 |
Im a huge e30 and e36 fan....and i really dig the e46m3....but this is when BMW begin to take this car up market and the reason for the high repair bills,the subframe problems are pretty sad for a car at this price....its a beast of car but for that price my money would be on a C5 Z06 all day long in the used market.
