02-08-2014, 01:46 PM | #519 |
Update:
I took my front pipe off because it wasn't working with the cat-back due to the end being warped. I'm working on getting a replacement. I installed the OEM front-pipe back on and hooked it up to the flowmaster cat-back. The car is very loud, much louder than I was expecting. I don't know if I will keep it on there. With my set-up it vibrates the cabin pretty hard and drones a bit when you're not at a certain throttle position cruising. I don't know, it's just not me. It has a nice purr to it at idle but just opens up way too loud and even at moderate throttle there's no way to keep it quiet: [ame="http://www.youtube.com/watch?v=KkO77EUZhnQ"]Flowmaster Cat Back on BRZ - YouTube[/ame]
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) |
02-08-2014, 02:50 PM | #520 |
Just a dude
Drives: Scion FR-S 2013
That's loud, I dunno if it's way mic picks it up but that's loudest interior clip I've heard in almost any vid of this car. :O
02-08-2014, 03:01 PM | #521 |
Drives: Scion FR-S
I'm jealous of all the parts you keep getting. My wife has this strange obsession with this thing called a saving account, it is really holding me back.
My build thread, slowly but surely http://www.ft86club.com/forums/showthread.php?t=40509
02-08-2014, 03:50 PM | #522 | |
I need to do that too. This was my last item for a while. I plan to do the clutch/flywheel down the road but I'm almost all done.
02-08-2014, 04:28 PM | #523 |
There's just so much cabin vibration at low rpms, otherwise I wouldn't care about the noise up top.
Here's a better video: [ame="http://www.youtube.com/watch?v=3htPK49Fs3A"]Cat Back Rd 2 - YouTube[/ame]
02-08-2014, 07:01 PM | #524 |
Drives: 2016 ISM BRZ Limited, 2000 Civic SI
Sounds so raspy. What made you choose the Flowmaster?
02-09-2014, 01:33 PM | #525 |
After taking my car for a spin, I though there's no way this is right, there has to be a leak, it's just too loud.
Turns out I didn't get the inlet pipe into the muffler in all the way. I readjusted and torqued the hell out of everything. Bad video but it's better now. Still pretty loud with a side of rasp, but better than before. It seems like the cabin vibration is coming from the muffler being really close to the heat shield under the trunk. I wonder if there is anything I can do to dampen that? [ame="http://www.youtube.com/watch?v=Gtzgprj_xNY"]Brz flowmaster rd 3 - YouTube[/ame]
02-26-2014, 10:36 PM | #526 |
TURBOLICIOUS
Drives: a machine :]
Man you're car looks beautiful! Tastefully executed indeed!
02-27-2014, 05:53 PM | #527 |
Update:
I finally received my replacement front pipe from FA20Club. I know people have been all over them and it did take forever to get here but I bought my original one back in June of last year and they still replaced it all this time later. I plan to run it up to @Pure_Automotive early next week to throw it on so I can get it up on the lift and check out my cat-back slip fits for any leaks and make some adjustments to reduce the drone from the muffler sitting close to the heat shield. I plan to also get some dyno pulls, so stay tuned. Should have some nice updates here in a few days. This time with a donut gasket that fits! Side by side with the original one I had:
The Following User Says Thank You to swift996 For This Useful Post: | chanomatik (02-27-2014) |
02-28-2014, 01:02 AM | #528 |
Seņor Member
Drives: 2013 Raven, Drifty things
Man I can't wait to start seeing track videos of this car this spring!
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris '13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross. |
The Following User Says Thank You to 6-Shift For This Useful Post: | swift996 (02-28-2014) |
03-06-2014, 04:53 PM | #529 |
Small Update:
Installed the new/replacement front-pipe It seems a little too loud/raspy with the cat-back. I might go back to the OEM cat-back. I'm going to put a few more miles on it and figure that out. My new brake set up (jk ZR1's) My tuner is ironing out some things but I was making about 25whp over my last run up to 5k rpms, had 210 torque at 4k rpms. Hope to get back up with a revised tune soon.
The Following 3 Users Say Thank You to swift996 For This Useful Post: |
03-12-2014, 12:43 PM | #530 |
Dyno Run:
My tuner is working on the misfire issue above 5500 rpms. Hopefully we can get that fixed soon. My exhaust is a little too loud so I plan to throw the stock cat-back on here in a couple weeks. This misfire issue seems unique to the intercooled version. Highlights: 215whp @ 5500 rpms and hit 210 lb/ft of torque @ 4000 rpms. So once things get worked out, I should be on track to make some solid power. NOTE - I have reflashed a new map. All the fueling was redone so take the old map/dyno run below with a grain of salt. [ame="http://www.youtube.com/watch?v=9L24mZuXoqU"]Innovate BRZ Dyno Run - YouTube[/ame]
The Following User Says Thank You to swift996 For This Useful Post: | frsvr4 (03-12-2014) |
03-14-2014, 12:44 PM | #531 |
Small update
I swapped back to the OEM MAP sensor and things are running good and smooth now. I'm hoping to get back to the dyno next week before I head to Europe if time permits. I should be in good shape now. Here is the run when I ran into the misfire issue:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) Last edited by swift996; 03-14-2014 at 12:58 PM. |
03-14-2014, 01:35 PM | #532 |
Drives: 2013 SWP BRZ
Glad the stock map sensor fixed your issue. Can't wait to swap mine back in too. Hopefully on the THIRD trip to the dyno, I can finally get tuned lol.
I took my front pipe off - car was too loud, especially on cold starts.. yikes. I was thinking of doing the opposite and taking the catback off, but I like a bit of sound. I'm hoping it doesn't really impact power, but I really doubt its going to. |
Similar Threads | ||||
2013 BRZ Limited (black) | Epictetus | Cars for Sale/Trade | 2 | 11-14-2012 11:38 AM |
My crystal black brz limited | chadz | Member's Car Journals | 37 | 09-12-2012 06:26 PM |
BRZ, Black, 6MT, Limited...DELIVERED! | boarder1995 | BRZ First-Gen (2012+) -- General Topics | 3 | 06-14-2012 04:03 PM |
Need a black AT Limited trim BRZ! | jaytaurus | Northwest | 4 | 05-18-2012 05:29 PM |
