Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
10-17-2018, 11:14 AM | #1 |
Drives: GTS 86
BLITZ gauges wiring instructions
Hi all,
I bought the BLITZ panel with their gauges - water temp, oil pressure and oil temp. It came with all sorts of wires but no damn instructions how they connect where. Does anyone have them installed and can share the wiring diagram or instructions by any chance? |
10-17-2018, 11:19 PM | #2 |
Drives: GTS 86
Here are the terminal ends that confuse me. Any help would be greatly appreciated.
10-17-2018, 11:44 PM | #3 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
isn't there a controller for those guages? I think it's called a Live unit 2 or something that the guages plug into.
Edit: I found this....don't know if these are the guages you got or not. http://www.manualsdir.com/manuals/ge...f6b8c58&open=1
10-20-2018, 12:03 AM | #4 | |
Drives: GTS 86
10-20-2018, 12:18 AM | #5 |
Drives: 2014 FR-S
is this what your talking about
10-21-2018, 09:50 AM | #6 |
Drives: GTS 86
10-24-2018, 11:53 AM | #7 |
Drives: 2014 FR-S
Not sure if you were to get this installed but here is a couple manuals I found. I could only find it in Japanese. I used google translate to read it and from what I gather those are continuous 12 volt, ignition 12 v, illumination, and ground. I'm not sure if you have everything for it but from what I can understand in the manual you only need one connection to the power/illumination source and you can daisy chain the rest together. There is also a manual on the GT86 gauge mounting and wiring, that is the second link. From what I can understand you can use a 15 pin connector located under the drivers side dash by the steering column and blinker relay for all the power sources.
Racing Meter SD manual Racing Meter SD set for GT86 panel install |
The Following User Says Thank You to KnightRyderx2 For This Useful Post: | Hawk77FT (10-26-2018) |
Similar Threads | ||||
Here are your Rocketbunny instructions! | Maverick22 | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 04-03-2017 12:52 PM |
Wiring gauges into Light Control & Fuse harness help | chris.mutchler34 | Electronics | Audio | NAV | Infotainment | 8 | 09-05-2016 08:05 PM |
DIY: hard wiring gauges, radar, etc to ignition | kam628 | DIY (Do-It-Yourself) Guides | 3 | 05-12-2016 09:41 PM |
Spec D headlight HID Install instructions/wiring? | jibai | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 04-05-2015 02:38 PM |
Instructions to install OEM mudguards? | eddieEndo | DIY (Do-It-Yourself) Guides | 7 | 02-13-2013 04:18 PM |
