Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
12-17-2015, 03:53 AM | #15 |
Drives: brz
everything is closed.
12-17-2015, 05:06 AM | #16 |
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | ru-x (12-17-2015) |
12-17-2015, 08:27 AM | #17 |
Press the key fob a second time. My 2016 does exactly this then I press the button a second time. Lights off
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
12-18-2015, 08:56 AM | #18 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Do you press the button twice or only once? My 2015 takes a double click of the lock button to shut off the lights. Wondering if all these things are just firmware differences across diff years. |
12-18-2015, 08:58 AM | #19 |
My 2014 is the same, headlights stay on forever it seems like if I don't hit it twice.
Kind of akward when you pull up to someone's house and the bright HId are shining through their windows |
12-18-2015, 10:41 AM | #20 |
Its a courtesy light for like walking to your door at night sort of thing.
12-18-2015, 02:09 PM | #21 |
Kinda what I figured. I always have friends reminding me that I left my lights on though. And I've had valets manually turn off the lights, and then my dumb ass drives around for 5 minutes at night with no headlights before realizing theyre off.
12-18-2015, 02:45 PM | #22 |
Drives: '16 Scion FR-S - Oceanic
'16 model with auto lights. Turns off after about 30 seconds, or I can press the lock key twice and it turns off right away.
12-21-2015, 05:11 AM | #23 |
Drives: brz
alright guys. I think i solved the mystery. I noticed that the window isn't auto moving up and down when i'm opening and closing the door...thus the car thinks the door is always closed. That would explain the lack of beeps when i turn off the car or when i have headlights on when the door is open while the engine is off. I'll play around thing and stuff when i get out there tomorrow.
12-21-2015, 09:24 AM | #24 | |
Drives: GR Corolla
12-23-2015, 07:16 AM | #25 |
Drives: はちろく
12-23-2015, 09:16 AM | #26 |
Drives: BRZ Limited; GR86
yea you have to hit the lock button 2 times
12-24-2015, 02:04 PM | #27 |
Drives: brz
yup, the door switch isn't stuck, but is faulty. it will be replaced. thankyou all for playing!
Similar Threads | ||||
How to turn BRZ Headlight LED into DRL | Lithium | DIY (Do-It-Yourself) Guides | 184 | 12-03-2017 01:57 AM |
Right headlight wont turn on | Matt90 | Issues | Warranty | Recalls / TSB | 9 | 11-11-2013 03:56 PM |
Passenger Door Courtesy Light Wont Turn Off | zex | Issues | Warranty | Recalls / TSB | 12 | 10-04-2013 01:31 PM |
Does the Toyota Corolla keyfob cover fit the FRS keyfob? | FRSHunter | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-25-2013 05:04 PM |
