10-26-2017, 04:08 PM | #379 |
Drives: white frs
Im planning to install a universal trans cooler but i dont have any idea how to and ive been researching and couldnt find any . Im curious if you need to add more trans oil after the install . And ive read that okce you add you need to reset or short the trans ecu if not the transmission will be on limp mode
11-14-2017, 08:19 PM | #380 | |
AutoX-10/10ths every run
I'd suspect that you will need more than the original amount of fluid as you're adding lines and a cooler to the system, how much I'm not sure. I've done 2 fluid changes on my car and I did not need to reset the ECU.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
11-14-2017, 08:34 PM | #381 |
So a little over 3 months ago I had the Direct Injector on Cyl 3 go bad. I didn't catch it until the damage was done, broken piston, scored bore. I sent out the DIs and PIs for testing after the fact and found that the DI on Cyl 3 stopped flowing fuel once it hit 225F.
I'm now working with Blue Moon Performance http://bluemoonperformance.com/ to rebuild. Here's a few photos of the carnage and new parts. Rough specs of motor are as follows: - Brand new Direct Injectors, lol - Over bored to 86.5mm - 11.75/1 compression - Custom Blue Moon Spec Carrillo rods and pistons - Reimax oil pump gear - Piper stg 1 cams - Blue Moon oil baffle - Stiffer valve springs - +1mm on exhaust valves - Polished intake and exhaust ports - WPC treatment http://www.wpctreatment.com/about.htm on all moving parts - non 2013 valve train components - and other Blue Moon specific tweaks to the build...
The Following User Says Thank You to whataboutbob For This Useful Post: | ichitaka05 (11-24-2018) |
11-29-2017, 06:42 PM | #382 |
Buttonwillow in March of this year.
12-04-2017, 01:44 PM | #383 |
The car is going to be back up and running soon thanks Bluemoon Performance (http://bluemoonperformance.com/) for the support!
12-24-2017, 02:09 PM | #384 |
Getting close.
06-25-2018, 05:30 PM | #385 |
Drives: 2014 BRZ
What is the effect of the Piper cams? More top end?
07-01-2018, 03:19 AM | #386 |
07-01-2018, 03:19 AM | #387 |
So much win going on with the car building right now.
11-02-2018, 12:27 PM | #388 |
Drives: 16' BRZ
You ever get back up and running?
The Following 2 Users Say Thank You to GrabTheWheel For This Useful Post: | whataboutbob (11-02-2018), ZionsWrath (11-02-2018) |
11-02-2018, 10:37 PM | #389 |
It's been a long process, but I should have it running this weekend. I've been working on a number of other supporting modifications, including an Accusump. I'll post some photos in the near future. You can see some of what I've been up to here: https://www.instagram.com/robert_stangarone/
The Following User Says Thank You to whataboutbob For This Useful Post: | ichitaka05 (11-08-2018) |
11-18-2018, 11:20 PM | #390 |
Car is running again now.
The Following 4 Users Say Thank You to whataboutbob For This Useful Post: | ichitaka05 (11-24-2018), mixxxx (11-19-2018), Racecomp Engineering (11-19-2018), TeutonicShift89 (11-26-2018) |
11-26-2018, 12:43 AM | #391 |
Drives: '13 LAVA - lightly modded
Wow! Has it really been down for almost a year? Glad you got it running again!
You are going to be condemned to live out the consequences of your taste - TM
The Following User Says Thank You to TeutonicShift89 For This Useful Post: | whataboutbob (11-26-2018) |
01-05-2019, 01:32 AM | #392 |
Check out the latest updates here:
https://www.facebook.com/RobertStangaroneMotorsports/ https://www.instagram.com/robert_stangarone/
Similar Threads | ||||
FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
Showstoppers Firestorm FR-S Build | ShowstoppersUSA | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 30 | 10-09-2014 05:26 PM |
Firestorm/black project build | deedz | Member's Car Journals | 47 | 11-19-2012 04:06 PM |
Firestorm FR-S Available | mattyboy311 | Mid-Atlantic | 1 | 09-26-2012 10:36 AM |
Firestorm Frs | DAFRS88 | Southern California | 0 | 08-03-2012 04:11 AM |
