Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
01-07-2018, 04:37 AM | #29 |
Drives: Frs
Were ou able to get the usb to work?
08-22-2018, 08:37 AM | #30 |
Drives: 2016 4Runner / 2016 FR-S
I don't know if you've figured it out already but since you have a BRZ head unit, it'll have the Subaru USB header on the back of the unit. you would need to purchase two separate adapters:
Toyota USB adapter: https://www.amazon.ca/Goliton%C2%AE-...70_&dpSrc=srch Subaru USB adapter: https://www.amazon.ca/FEELDO-Adapter...aru+usb+female You would basically have to cut both of these adapters and attach them together so you'd end up with the Subaru header on one side and the Toyota header on the other side. Wiring should be basic as it most likely follows the USB wiring standard which consists of four wires: Black - ground Red - +5V Vcc Green - USB data + White - USB data - The Toyota side would plug into the harness that leads to the USB port, and the Subaru side would plug into the back of the unit.
I pay more per month for insurance than I pay for the FRS.
The Following User Says Thank You to itsAlex For This Useful Post: | Clipdat (08-22-2018) |
08-22-2018, 02:24 PM | #31 | |
Proud of BOXER
Drives: Subaru Boxer
I actually haven't yet tried to use that special OEM Subaru cable that I ordered. I'm pathetic.
Anyway, I can try it soon, I just need to figure out the easiest way to pop out that little usb/aux input thing.
Similar Threads | ||||
2017 Toyota 86 head unit help..... | PetrolioBenzina | Electronics | Audio | NAV | Infotainment | 77 | 02-03-2018 01:55 AM |
2017 toyota 86 head unit is pissing me off | Cosmo Kramer | Electronics | Audio | NAV | Infotainment | 15 | 03-20-2017 04:44 PM |
2017 BRZ head unit? | giggidy | CANADA | 1 | 03-04-2017 08:46 PM |
2017 Series.Yellow with Old Head Unit?! | Stang70Fastback | Electronics | Audio | NAV | Infotainment | 5 | 02-15-2017 03:22 PM |
2017 Toyota 86 head unit help..... | PetrolioBenzina | Electronics | Audio | NAV | Infotainment | 0 | 10-16-2016 09:01 PM |
