Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-22-2017, 09:41 AM | #15 | |
Drives: 2015 Scion FRS - Asphalt
Pictures don't do these wheels justice. |
02-22-2017, 11:03 AM | #16 |
Big in Japan
Drives: turBRZ
-4 deg camber is quite a bit and you would notice it much more than what's in the pics you posted. To me, this looks like 2-ish. You get a good bit of camber just with lowering the car 1". The lower you drop, the more negative camber you get in the back. The LCAs are needed, typically, to reduce the negative camber in the back.
05-10-2018, 01:09 PM | #18 |
Drives: Track preped NA FRS
If you have the same problem, it might be the offset toe bushings that came the LCAs. You can install them in several ways, to maximize negative camber or to minimize it. I had mine installed to maximize it since I though that maybe I wont have enough adjustment for what I wanted. My rear camber is at -3 when the toe is set to 0, at barely lower than stock ride height in the rear. If I wanted to reduce the negative camber more, I would get toe-out in the rear. Maybe this is your problem? Buying adjustable toe-arms will indeed allow you for a greater adjustment in camber while keeping the toe in check.
Similar Threads | ||||
FRS Bumper alignment issue, help please | Brody602 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 06-04-2015 02:27 PM |
Do I just need an alignment or... (scraping issue) | IDFWU 420 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 12-26-2014 12:26 AM |
Alignment issue | guscab | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-08-2014 10:26 PM |
Alignment Question and issue | whitefrs | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 03-31-2014 07:42 AM |
