Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
03-04-2018, 06:01 AM | #15 |
Drives: UK GT86
Here's mine for reference. You can see where CL starts at the brief blip of off throttle. AFR in red, commanded in yellow:
.: Stealth 86 :.
02-21-2019, 04:17 AM | #16 | |
Drives: brz 2017 hksv2
i get it too (somehow shorter duration than your log but kinda similar) even with rear o2 fitted but CL#3 / AF #3 disabled(zeroed) in tune regardless if it s a prerestyling or not (all euro cars) i also think ecutek doesn t have ALL af#3 correction/learning tables defined so i think at least one table for it i cannot zero |
02-23-2019, 12:58 PM | #17 | |
Drives: UK GT86
.: Stealth 86 :.
02-23-2019, 04:52 PM | #18 |
thanks
unluckily it does the same with rear 02 fitted (but disabled), and if enabled it does that strange swing rich-lean around 14.7 on cruising and often apply a little AF#3 correction to the open loop and it is annoying all of these i could try your way too, maybe directly with CL of racerom10, but i did try something like that month ago and couldnt get it working smoothly... did you zero the af#1 correction tables (stft) ? or just modify other tables to disable stft at a certain load, lower than 0.7-0.8 of stock logic? and how ? :\ |
02-25-2019, 01:37 PM | #19 |
Drives: UK GT86
@tomm.brz I just set the Minimum OL AFR value to around 14.7 and the fuel map to a touch below so it goes OL in cruise and then use a custom map to do CL cruise fuelling. It even allows leaner burning, which is why I did it.
.: Stealth 86 :.
02-25-2019, 02:11 PM | #20 |
God, seems even better than my running leaner because i offset the front lambda scaling :P
and i use happily and bugless racerom 10 CL fuel control so i can save me the custom map for the CL fueling I ll try, thanks kodename |
Similar Threads | ||||
is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 02:20 PM |
Need downstream O2 sensor ASAP! | mtimney | Engine, Exhaust, Transmission | 8 | 11-06-2013 12:12 PM |
02 Sensor | mjsivee | Engine, Exhaust, Transmission | 4 | 06-13-2013 01:58 PM |
Bad MAF Sensor | paulieblaze | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 08-23-2012 10:34 PM |
Stock O2 Sensor | d1ck | Engine, Exhaust, Transmission | 1 | 07-11-2012 07:16 AM |
