07-19-2019, 12:55 AM | #8569 |
Drives: 2017 toyota 86
Jon bond has all the parts for it if you know how to fix it. Or he may be able to repair it if you ship to him. I believe he also has completely built ones ready to go as well.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | kev0 (07-19-2019) |
07-19-2019, 02:01 AM | #8570 |
Drives: '14
As far as the vacuum actuator goes, does the one from JBP differ from any other one I find with the same part number?
https://jonbondperformance.com/index...roducts_id=146 and https://www.magnusonsuperchargers.co...-01-31-764.htm |
07-19-2019, 03:18 AM | #8571 | |
07-19-2019, 07:25 PM | #8572 |
Just the tip
I had to buy a replacement vacuum actuator years ago as the plastic came loose from the metal bracket. Poor design in my opinion. I got my from Sprintex directly. A little tedious to get it on and the arm thing in the correct position.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
The Following User Says Thank You to stockysnail For This Useful Post: | kev0 (07-19-2019) |
07-19-2019, 09:50 PM | #8573 |
Drives: '14
What were your symptoms with the failing vacuum actuator?
07-21-2019, 08:37 PM | #8574 |
Drives: 2013 Scion FRS
Anyone got tips for taking those pesky hex screws out on IC install? Considering just removing the whole damn thing
Sent from my HTC6525LVW using Tapatalk
ScreamingElectron - SnakeShit |
07-21-2019, 08:50 PM | #8575 |
Drives: Boosted Toyobaru
I've had my sprintex supercharger installed and pro tuned for just over 2 months and got a Check Engine Light today after turning the car on. Im still putting the same 94 octane as per the map requires. I dont know what code it is at this moment.
Has anyone experienced this before, what do you recommend doing about this? |
07-21-2019, 09:46 PM | #8576 |
Drives: 2015 Firestorm 08/05/15
If you are on Ecutek tune, plug in your dongle spool up the Ecutek tune file you have the ability to read the codes and clear them. Go to Ecutek website . They have great tutorials for diy,s. Google is your best friend.
07-21-2019, 09:48 PM | #8577 | |
2013 Series 10 FRS #553
07-21-2019, 09:56 PM | #8578 |
I do have ECUTEK tune. I paid for licensing and the tune but I never got a dongle or cable. Was this suppose to be given to me when i bought ecutek license?
07-21-2019, 10:01 PM | #8579 | |
The Following User Says Thank You to jflogerzi For This Useful Post: | JDM_Import (07-22-2019) |
07-21-2019, 11:04 PM | #8580 | |
If iPhone dashcommand |
07-21-2019, 11:08 PM | #8581 |
He is correct. They are extra, you can find them for around 200.00 used on the forum.
07-22-2019, 12:50 AM | #8582 |
Just the tip
Something just didn't feel quite the same. It was subtle and hard to explain. I frequently look under the hood and noticed it.
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
