05-07-2015, 04:09 PM | #141 |
Drives: BRZ Limited [37J]
So brake calipers are specifically designed for just a specific car like the BRZ right? Wrong, I doubt most people know that the BRZ front calipers are from 08+ WRX and rear calipers are from the 10+ Legacy GT. Yes, the same WRX that can be fitted with the STi Brembos front calipers. We're running calipers that are made to stop 3300+lbs car and not specifically designed for the BRZ. Just a food for thought.
05-07-2015, 04:22 PM | #142 | |
Drives: 2013 Firestorm FR-S
The point about the stock calipers being made to stop a 3300+ lbs car actually adds more validity to my statement that with a few easy upgrades (pads, fluids, and lines) the OE calipers are more than sufficient for most people's cars.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
05-07-2015, 04:40 PM | #143 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Lmao let this thread die, white knights! Let it die!!!!!
Top Tier Imports - Check out my build journal HERE
05-07-2015, 05:17 PM | #144 |
It's fine on the street but once you're on the track you're going to cook your brake. The advantage of running BBK is having higher heat capacity because of the larger rotors to help with brake fade.
The Following User Says Thank You to BunnyRZed For This Useful Post: | CSG Mike (05-07-2015) |
05-07-2015, 07:24 PM | #145 | |
Let me repeat: you have LESS braking force in the rear with the STI Brembo rear caliper, than with the stock FRS/BRZ rear caliper. |
The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
05-07-2015, 07:26 PM | #146 | |
Yes, the brakes are parts bin parts, but no, the bias is completely different from the other two cars. Thats why they were mixed and matched, instead of lifted straight from one car. On that note, the front caliper is from a 268hp/3200lb car, and yet, is insufficient for experienced drivers on a 200hp/2700lb car, even with upgraded pads. Makes you wonder how underbraked a lot of street cars are... |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | DylanJZA (01-31-2023), Shark_Bait88 (05-08-2015) |
05-07-2015, 07:27 PM | #147 |
Except... you're overloading the fronts, so the increased heat capacity is overshadowed by the disproportionately larger amount of heat generated by the front calipers.
05-07-2015, 07:29 PM | #148 | |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
oh i give up. i'l just check in once in a while to make people know i didn't die, yet. |
05-07-2015, 07:54 PM | #149 | |
Road-hole
Drives: 2013 Whiteout FR-S
exactly what I was thinking...
Jaden |
05-07-2015, 08:17 PM | #150 | |
05-07-2015, 08:23 PM | #151 | |
05-07-2015, 09:21 PM | #152 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | Jive Turkey (05-08-2015) |
05-08-2015, 05:39 AM | #153 | |
001 of 012
Drives: MY12 NZDM Subaru BRZ "BRZ001"
I would be surprised if the specifications for the piston size were original at the time of prototyping. Brembo's knowledge base means that they can just plug in metrics and the job is largely done. I find it difficult (but not impossible) to believe AP incur more cost on developing a bracket than any other component in a kit. Its a block of machined alloy - providing you know that the quality your ingot manufacturer is outputting is high and quantifiable (ISO) its not rocket science building a brake bracket.
BRZ001: Peace Love and Wheelies @metabrz on IG
05-08-2015, 08:22 AM | #154 | |
Also, a lot of parts companies will sell their own products to other offices/plants within the same company at a mark-up. So by the time it reaches the end consumer the price can be heavily inflated, and this can happen disproportionately so depending on the region.
Similar Threads | ||||
The Truth Will Set You Free~ | Kiske | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 01-06-2015 07:53 AM |
Moment of truth. Humor is welcome! | gt8613 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 11-11-2014 02:08 PM |
any truth to this? | fluffy-reindeer-slayer | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-11-2014 08:00 PM |
An inconvenient Truth | Maxim | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 06-17-2011 10:35 PM |
