04-16-2014, 02:05 PM | #967 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
04-16-2014, 03:58 PM | #968 |
Regional Moderator
Drives: 13' ZN6 / 00' AP1 / 20' A90/ 15 EVO
Lmk when you go. I wanna get my car up on the lift to check out what's rumbling underneath.
04-16-2014, 07:36 PM | #969 |
Drives: 2014 BRZ SWP LTD
Darren, would you guys be able to swap transmission/ rear diff fluid in the garage?
04-17-2014, 12:15 AM | #970 |
NW Region Moderator
Drives: FR-S No More
Yeah.... we need to schedule it when someone else isn't using the lift, though. When are you thinking?
04-17-2014, 01:52 AM | #971 |
A Very Powerful Wizard
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
Hey pal,
Let me know when you've got time for a backup camera install |
04-17-2014, 10:24 AM | #972 |
i'd def do this if i knew what days you had in mind
04-17-2014, 12:52 PM | #973 |
The Following User Says Thank You to Turbo95eg6 For This Useful Post: | DarrenDriven (04-17-2014) |
04-17-2014, 01:50 PM | #974 |
NW Region Moderator
You thinkin this weekend? Maybe on Sunday during the day... text me Sunday morning when you get up.
04-17-2014, 01:51 PM | #975 |
NW Region Moderator
04-17-2014, 04:39 PM | #978 |
04-18-2014, 09:59 AM | #979 |
Boosted Member
Drives: 2013 SWP BRZ Limited
Sportline springs are 90% for looks only on a budget. It rides and performs like shit imo. The stock struts were not designed for the shortened springs, and harder spring rates so it throws off the balance for grip cornering. The stock dampers/springs are pretty damn good, according to some very credible track drivers.
The buttdyno will suggest that it rides stiff, thus it must be cornering better. It will lower your CoG, so maybe better for drifting. I have the Sportlines just to get rid of the fender gap, but any spring or sub $1k coil over setup will be a downgrade from the stock suspension system, pure performance wise. You will get camber in the rear once its lowered, I have -2.1L -2.2R. There is a possibility that you might get "wacky" camber, where it does not even out in the rear, in that case you will need to get LCA's to fix the issue. There will be camber wear with -2 in the rear. The biggest improvement I felt handling wise, was adding camber in the front with camber bolts (-1.4). Sway bars will make a difference over tower bars (upper strut bars), and I always believed to stiffen up the suspension from ground up, not the other way around. Put some thoughts into sway bars, if you want over steer or under steer correction. This will change with spring rates/damper settings with your suspension so it should be one of the last things to touch. Don't forget sway end links, the OEM ones will not hold after you stiffen up the sways. Suspension work is very very difficult, more so than adding power. This is why I'm falling behind on this part of modding, add the power to satisfaction first, then upgrade suspension.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12 |
04-18-2014, 08:00 PM | #980 |
@DarrenDriven i work every other weekend and have this weekend off. soo may 2-4... 16-18.. and so on.
The Following User Says Thank You to Ris For This Useful Post: | DarrenDriven (04-19-2014) |
Similar Threads | ||||
SoCal: any local shop to install springs | jgonx213 | Southern California | 12 | 12-16-2013 02:20 PM |
Coilover and Springs Install at Performance Shop | F-T | Mechanical Maintenance and Tools | 22 | 12-12-2013 01:12 PM |
WTB RCE spring or RS*R spring mounted on stock strut | jshum | Want-To-Buy Requests | 1 | 10-11-2013 02:47 PM |
Need to find a shop in Chico area for spring install | Senzai | Northern California | 1 | 08-08-2013 05:59 PM |
Garage FR-S at home or pay a shop/someone else? | ProTekk | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 10-30-2012 12:17 PM |
