Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-04-2013, 03:03 PM | #1 |
Drives: 13 White MT FR-S
Sitting on the side of the road. coolant all over engine bay
Just going down the interstate and cel comes on, coolant hot or low sensor voltage. Pull over coolant is almost at 300f and oil at 270f . Coolant is all over the engine bay like a bad Japanese porno. I have no idea what has happened. Waiting on tow truck atm.
08-04-2013, 03:10 PM | #2 |
Drives: car
When and what was the most recent work done in the engine bay?
08-04-2013, 03:15 PM | #3 |
Catch can on the pcv line last week. Been running fine though.
08-04-2013, 05:20 PM | #4 |
Drives: Asphalt Scion Frs 6MT
Wow thats odd, did you hit something? the caps look in tact I'm almost thinking the radiator ruptured
08-04-2013, 05:25 PM | #5 |
Grip>Slip
Have you been able to locate the source yet?
08-04-2013, 05:51 PM | #6 |
Car is sitting at my brothers shop until morning. Currently drinking heavily. Will report asap.
08-04-2013, 06:39 PM | #7 |
Drives: 2013 Asphalt FR-S
That's kind of what im thinking as well. The upper hose looks to be ok. A head gasket could do this, but it would be odd, and most of the spray seems to be heavy on the front of the engine. What was the temp gauge reading? I wonder if it overheated, then boiled over through the overflow tank or rad cap???
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703 |
08-04-2013, 07:15 PM | #8 |
Yeah it looks like it overflowed into the fan or something. What would cause it to overheat though. Please not head gasket.
08-04-2013, 10:40 PM | #9 |
is better than you
Drives: 2013 raven FRS
08-05-2013, 01:34 PM | #10 |
I hope its just a radiator crack, and not HG...I remembered when I changed the oil, the coolant was a little low, but my brother didn't have the right antifreeze the maintenance book called for so he just topped it off with the normal stuff he had. Could this have caused the antifreeze to
gunk up in the line somewhere and then blow? It couldn't have been more than a few mL.
08-05-2013, 01:40 PM | #11 | |
08-05-2013, 01:41 PM | #12 | |
Drives: DGM BRZ
What was the water-to-coolant ratio used? Looks more like a radiator failure than the engine. |
08-05-2013, 01:46 PM | #13 |
Not sure, what ever was from the factory. Engine still runs fine, I cranked it up for a minute or two last night. No smoke, or noises, everything seems to run fine.
08-05-2013, 01:48 PM | #14 |
True, I don't know, we just didn't.
Similar Threads | ||||
Checking and Changing BRZ/FR-S Engine Coolant | GrimmSpeed | DIY (Do-It-Yourself) Guides | 39 | 05-29-2023 08:15 AM |
Green engine coolant used quickly? | Tylub | Issues | Warranty | Recalls / TSB | 19 | 06-19-2013 01:15 PM |
Engine Coolant? | L3P47 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 04-13-2013 11:33 PM |
Normal Engine Coolant Temps? | Dezoris | Engine, Exhaust, Transmission | 1 | 04-05-2013 03:17 PM |
What's Everyone's Mileage Sitting At Right Now? | IchigoIchie | CANADA | 28 | 08-11-2012 11:56 PM |
