DIY (Do-It-Yourself) Guides For all DIYs. |
04-21-2013, 12:41 PM | #15 |
Tire Destroyer
Drives: Firestorm+snail
any problems? How hard was it? I've never done this kinda thing and the shop is quoting me double what the springs cost to install.
322whp/273wtq
04-21-2013, 01:46 PM | #16 |
Drives: SS BRZ LMTD 6MT, 92 Civic hatch RHD
This would work very well for the fronts. I thought about this after i had done my first front, but it was too late. Also i didnt have a hollow ratchet. I will be buying one if i ever do this again, as this way is superior to what i did. Although on the rear i think it would make the strut harder to remove because it would increase the length of the whole assembly.
I used my impact gun, but i was careful not to hold down the trigger. Also i lubed the top bolt first. I set the gun on high power, and lightly tapped it in short bursts, this worked pretty well. Also, i just stand on top of the spring and when the top bolt finally comes off, the strut only shoots a few inches. Its not under that much pressure, this is what i've done for years with my hondas. please note that on other cars this is definitely not safe. but on this car, its not a problem. |
04-21-2013, 03:35 PM | #17 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
I like this, well done.
The Following User Says Thank You to Deadspool For This Useful Post: | im2fr-s (04-21-2013) |
04-21-2013, 03:40 PM | #18 | |
Drives: 2015 Mustang GT (on order)
04-21-2013, 04:07 PM | #19 |
WOW! Thank you! Keeping this for future reference!
04-21-2013, 07:26 PM | #20 | |
Things to note for a newbie like me: Instead of using a long allen wrench to hold the shaft in place, I used a hex screwdriver... which essentially, IS a super long allen wrench. It worked beautifully; no vice required. I'd say the hardest parts were removing the 17mm bolts from the rear control arms (steps 37 - 42) and putting it all back. It took a bit more force and wriggling than I expected. It definitely helps to have a buddy work with you here. Make sure you orient your springs correctly. My springs (Swift) have their sticker logos upside down, which was a bit confusing at first. When I jacked my car down, I did the front first, and my jack ended up getting stuck under the car. You'll have to let down the rear first before letting down the front. Otherwise, the car will tilt down and there might not be enough clearance to move your jack out from under your car. Lastly, the Swift front springs were considerably shorter than the stock springs, so when the car was jacked up, the strut assembly was not yet high enough to fit into the top screw hole. As a result, the entire hub would slant downward toward me when I tried to install the wheels onto the car. So while a friend of mine lined up the strut assembly, I lowered the front of the car with a jack to the point where the weight of my wheels would have no clearance to fold the assembly down. Pretty much, my car was at a height so that when I installed the front wheels, the wheels were already just barely touching the ground. ^That paragraph seems confusing. I'm sure you'll understand it if you actually run into it. All in all, I'm definitely happy that I was able to do this rather than bring it to a shop. There's this weird sense of accomplishment when you are able to take apart your own car, upgrade it, and put it back together. DIYs like these are why I love this forum so much. |
04-22-2013, 01:26 PM | #21 | |
04-27-2013, 02:44 PM | #22 |
These instructions worked PERFECTLY! Thank you so much! One additional plus about doing it this way (at least this worked for me...I make no guarantees) is that you don't actually have to remove the front struts. You disconnect the lines and the sway bar and you can pull the strut down and rotate it out far enough to swap the springs and bump stops without removing the strut at all! Didn't get a pic, but it should be obvious once you get to that point. Also, use a jack to lift the rear control arm so the top of the strut goes through the hole. That way it holds it in place so you can start the nut inside the trunk. helpful if you're doing the job by yourself!
Ultramarine 2013 Scion FR-S 6MT
04-27-2013, 07:29 PM | #23 | |
04-30-2013, 10:15 PM | #24 | |
Drives: JRSC'd Asphalt FR-S
04-30-2013, 10:41 PM | #25 |
I dont like how easy this DIY is, need to find something more difficult and dangerous.
The Following 3 Users Say Thank You to Dezoris For This Useful Post: |
04-30-2013, 11:38 PM | #26 | |
You don't have to disconnect the rear sway bar. You do have to disconnect the front. I'm not sure if you can just loosen the strut bolt in the rear and pivot it out, but I found it was just as easy to remove that bolt (very easy access) The long answer: So, the way I did it was: - Remove top bolts from all 4 struts (using the allen wrenches and open sockets) - Loosen lug nuts - Raise car into air and put on jackstands - Remove wheels - FRONT: 1) Unclip ABS sensor wire (2 spots on both sides) 2) Unbolt brake line from strut assembly (both sides) 3) Disconnect sway bar end links (both sides) 4) Pull DOWN on strut assembly until the top rod pulls out enough to where you can rotate it TOWARDS you 5) Slip off old spring/bump stop 6) Put on new spring/bump stop and ORIGINAL rubber hat (not sure what it's actually called, but it's lightly press-fit onto the top of the spring) 7) Maneuver rod near hole 8) Lift up on the rotor to compress the suspension enough to get the nut started on the rod (top of strut tower inside engine bay) 7) Put everything back together again - REAR: 1) Remove bolt from hub/control arm 2) Remove bolt from strut/control arm 3) Pull DOWN on strut/control arm until rod clears the hole 4) Slip off old spring/dust shield/bump stop 5) Slip on old spring/dust shield/bump stop 6) Maneuver control arm/strut down so that the rod is near the hole 7) Reinstall bolts for hub/control arm and strut/control arm 8) Use jack to push up on control arm enough to allow you to start the nut on the rod (top of strut tower inside trunk) - Replace wheels and lightly tighten lug nuts - Gently lower car onto ground - Tighten up nuts on top of strut rods
05-01-2013, 12:16 AM | #27 |
Drives: Attitude
That is a rubber isolater to prevent metal/metal contact and NVH between the spring and top hat. If that isn't properly seated or slips during assembly, you will hear unpleasant noises as you're driving around.
05-01-2013, 12:20 AM | #28 | |
Similar Threads | ||||
Alignment needed after front camber bolt install? | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 60 | 08-31-2013 12:13 AM |
Exhaust MP/FP (flange/spring bolts) install help! | rbizzle004 | Engine, Exhaust, Transmission | 9 | 03-04-2013 11:34 AM |
East bay shops for spring install? | WillBRZ | Northern California | 9 | 02-21-2013 02:03 AM |
Selling stock strut/spring assembly | SleekMachine | Brakes, Suspension, Chassis | 16 | 12-13-2012 08:03 PM |
vibration after spring install? | sajonf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-30-2012 02:30 PM |
