Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-21-2012, 07:49 PM | #57 | |
Drives: Asphalt FR-S MT
07-21-2012, 08:00 PM | #58 | |
Señor Member
Drives: white BRZ 6MT
^lists benefits lmao
07-23-2012, 01:14 AM | #59 |
Drives: 97 itr sold
No, just service them properly and they will last the life of your vehicle , maybe wipe some oil off of your brand new filter, and put it in http://www.knfilters.com/news/news.aspx?id=157
FR-S #56 of 86 Raven MT ***FOR SALE***
05-27-2013, 11:47 PM | #60 |
Drives: Asphalt
Drop in filter
05-28-2013, 02:55 AM | #61 |
Drives: 14' Monogram FRS, ulramarine, white
I have an auto and with the K&N filter there is no more lag in my throttle response... The stock paper filter was starving the engine of air off the line and at the top end... The K&N drop on has helped enough for me to notice a difference and I have many other cars to compare it to. For anyone with an automatic that doesn't want a CAI this is what you should go with... Not to pricey and you get a good product that allows your vehicle to breath freely.
whether it be low and slow, fast and loud, or riding on rails, make it unique and make it your own.
05-28-2013, 08:55 AM | #62 |
Drives: FR-S 6MT
Read this info.. A real unbiased test from a well known knowledgeable source
http://www.bobistheoilguy.com/airfilter/airtest1.htm Basically.. His tests reveal that the foam/oiled filters do flow better.. But at the cost of allowing dirt in your engine. That the difference is negligible and not worth the minimal gains if any.. That the stock setup is more than adequate and filters better. I'll stick with stock setup and sacrifice that .2 HP increase for longevity.. "The factory airbox and piping with no filter yielded a pressure drop of 5.0 inches of water or 0.18 psi. That means that the worst filter in this test only caused a pressure drop of 0.07 psi. In my opinion, this means that if you are picking an air filter based on performance, you probably aren't doing your car any favors." |
The Following User Says Thank You to Mikem53 For This Useful Post: | ubersoph (06-27-2013) |
05-28-2013, 02:56 PM | #63 |
Life to short to be slow!
Drives: Toyota GT86
Wow most of you guys are filter Nazis... this is better, no this is better... let the guy post his opinion on his filter and drive on. Why all the critics here like you are some mechanical engineer and you did a lot of test to come to the conclusion that k&N suck. I had it for years in my GTI 1.8T no problem what so ever I have it now in my FRS 10,000 miles no problems yet.
So if you don't like K&N keep the opinion to yourself we just don't care about critics most of you came from a Civic anyway. I bet there is no horsepower gains or maybe 2hp I dont know havent dyno my car yet, but I just dont like the way you critiziced others is not a good way in my book, FAN BOYS! |
05-28-2013, 03:18 PM | #64 | |
Drives: 2017 Fiesta ST
The Following User Says Thank You to OnkelC For This Useful Post: | kombatlion (05-28-2013) |
06-27-2013, 08:12 AM | #65 |
Drives: 2014 GLI Autobahn/Nav
[ame="http://www.youtube.com/watch?v=3DbkmThHYMs"]2013 Scion FR-S Intake: K&N Replacement Filter Dyno Test - YouTube[/ame]
So I found this today. Why would anyone replace the full intake system if this is true? It appears just a drop in grants the same gains as the full $400 TRD system. Now I'm no mechanic. Can anyone speak to this in a more technical level? |
06-28-2013, 02:00 AM | #66 |
Drives: Passat
Every car is different. Scion TCs and XBs both gain over 10whp from most CAI's but almost nothing from drop-in filters. In their case the restriction is in the airbox and/or intake piping while in our case the small panel filter appears to be the biggest restriction. My XB had a much larger panel filter than my FRS despite making only 160bhp.
BTW I installed a K&N filter today and was very disappointed to see how little surface area the filter has. I don't remember previous K&N filters having so much excess poly clogging the filter media around the perimeter. I'd estimate that the K&N has about 1/2 the filter surface area of the oem Denso. In order to flow better than oem the K&N has to utilize a much coarser filter media, which it obviously does. I just hope it's worth all the extra dirt in my engine for the 5whp peak hp gain. |
07-03-2013, 02:53 AM | #67 | |
Drives: 2017 Subaru BRZ PP
BTW, I just noticed these filters are also used for several other Toyota engines, not Subaru engines. Yet another part that's Toyota based. :P
Toyota + Subaru =
07-03-2013, 12:30 PM | #68 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
Installed mine about a week ago, no major registry on the butt dyno except for some minor improvement in throttle response and MAYBE some top end power that is hardly noticeable. Definitely minor audible changes in the 5k-7k RPM range (with the noise generator still attached, at least). Estimating a 2-5hp depending on where in the RPM range you measure.
For $40 and 15 minutes, it was worth it to me despite there not being a drastic improvement. Nobody should honestly think that an air filter is going to make a night and day difference in their vehicle, but it won't make a night and day difference in your wallet either... EDIT: This is before my exhaust system is installed. I would expect the air filter will become a little more useful when I can pump a little more air out as well. |
07-03-2013, 02:09 PM | #69 | |
Drives: Passat
I really like Subaru but the more Toyota the better, IMO. |
07-03-2013, 03:38 PM | #70 | |
BMC has more prestige than any other since they are used in race winning F1 cars, Le Mans/GT cars, MotoGP bikes, etc, but I still think Green has a slight edge in quality.
Toyota + Subaru =
The Following User Says Thank You to Bristecom For This Useful Post: | Tomzilla (07-17-2013) |
Similar Threads | ||||
K&N drop in air filters..............will you? | Liquidsnake | Engine, Exhaust, Transmission | 94 | 10-23-2014 09:04 PM |
Wheel Directory: Advan RG-D 18x8.0 +45 | wtf.bbq | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 45 | 09-11-2013 05:36 AM |
K&N Drop In Filters! Available at Vivid Racing!! | vividracing | Engine, Exhaust, Bolt-Ons | 6 | 06-29-2012 05:53 PM |
Alignment needed after lowering car? | Lowellrenzo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 06-16-2012 02:57 PM |
TRD Drop in AF | feldy | Engine, Exhaust, Transmission | 2 | 06-05-2012 08:40 PM |
