Old 12-05-2023, 10:34 AM   #15
Rex1585
Out of curiosity, can you not just reflash the ABS module instead of getting a different one from a manual car?
Sent from my Pixel 7 Pro using Tapatalk
Rex1585 is offline   Reply With Quote
Old 12-06-2023, 02:32 PM   #16
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by MujisGarage View Post
This to note with this swap guide!
This is for a 2017+ BRZ/86 however majority of the points will work for the 2013-2016 year models.
(For the Front chassis harness you'll most likely be able to repin it so you dont have to remove and replace it)
For 13-16 there are a few Modules you want to swap over such as the ECU & BCM! You will also need to replace all interior electrical components from the SAME CAR, the reason being is because these model years have an issue with the immobilizer tweaking up on you. You need a list of immobilizer components to swap over such as:
BCM, Cluster, ECU, ABS, Donor Key, Key Cylinder, Interior dash harness and the Power steering module.
If anyone is looking to do the swap, I'm currently working on it myself RIGHT NOW! So if you have any questions DM me on IG @MujisGarage.
Just want to clarify but you used 17+ parts for the swap on a 13-16 car and these are the additional things you had to do?
brz, frs, manual, swap, transmission
Auto to Manual Transmission Swap MenoSkyz Engine, Exhaust, Transmission 20 03-16-2018 01:54 AM
Transmission swap: auto to manual... itdansharpe Engine, Exhaust, Transmission 39 02-12-2018 04:53 PM
Is there anyway I can swap out my automatic transmission to a manual Kushbrz13 Engine, Exhaust, Transmission 23 01-02-2016 06:10 PM
Looking for Swap or trade 2013 86 gts manual to auto Xylon Australia Classifieds 0 12-16-2015 11:12 AM
