04-07-2015, 04:42 AM | #323 |
Drives: '13 FR-S
@Dezoris I am also concerned. I don't think it's pinging/knocking but it doesn't exactly sound like VTEC, yo. It sounds like my Honda Insight valves when the motor was cold and the oil needed to be changed.
04-07-2015, 01:51 PM | #324 |
I had the aggressive VVT tuning removed from the tuning and noise was gone. No one has been able to explain mechanically what is causing the noise so I opted for safety.
04-07-2015, 07:08 PM | #325 |
Drives: '13 FR-S
@Dezoris
Thanks for the reply. How would I go about removing the aggressive VVT tuning on my OFT? I understand this question may be out of scope but I thought I would ask. I ran an experiment today: 1) Smooth, light acceleration from start to high RPM - No buzzing 2) Hard acceleration from start to high RPM - Buzzing 3) Light accel around 4000 RPM - no buzzing 4) Hard accel around 4000 RPM - Buzzing What I found is that the noise is not dependent on RPM as much as it is dependent on load. With that said, do the VVT maps account for load? If they don't, then there is something being stressed in the motor due to load, which is causing the sound. This would make the hypothesis that the sound is due to valve overlap (or even simple mechanical resonance) a bad one. I believe both valve overlap and mechanical resonance should rear their ugly heads at a specific RPM, not necessarily a specific load. |
04-07-2015, 11:17 PM | #326 | |
Drives: Toyota 86
04-08-2015, 12:21 AM | #327 |
Drives: '13 FR-S
@ztan thanks for the advice!! Will check it out tonight. Is there a way for me to edit own VVT map and is it safe?
04-08-2015, 01:30 AM | #328 | |
Drives: Toyota 86
Lots of good threads on NASIOC and other Subaru sites about engine tuning in general. http://igotasti.com/vBforum/archive/...hp/t-4616.html Td_d: "Do not take the process of AVCS tuning lightly. You will blow shit up." |
04-08-2015, 07:27 AM | #329 | |
Drives: '23 BRZ Limited
I'm amazed that you still don't understand how cam timing and overlap can affect induction noise. You remember the old Honda/Acura AEM intakes? The specifically used tuned resonance to force more air into the cylinder. Or like these guys that modify the intake manifold to take advantage of intake reversion to increase midrange torque. http://www.metricmechanic.com/produc.../baby-six-m20/ Or like many cars today that have dual-stage intake manifolds one for low rpm and one for high rpm. It's not difficult to understand, really. |
04-08-2015, 07:58 AM | #330 | |
And in this case the VVT optimizations it raised red flags, and everyone who was in the car who heard the "resonance" said it sounded horrible. At to have it at 3000-4000 rpm under partial throttle every shift is absurd for.daily driving.
04-08-2015, 01:15 PM | #331 |
Drives: '13 FR-S
@Shiv@Openflash Any chance you have a "non-aggressive VVT" tune available for OFT as Perrin has provided @Dezoris for their tune? I love everything about the OFT Stage 1 tune except the sound is very concerting.
Thanks in advance! |
04-08-2015, 01:46 PM | #332 | |
It is like a public concert. Were you looking for disconcerting or concerning? I just find this all quite humorous. Buy a lightweight, loud, rough riding sports car, start modifying it and then complain about a brief harmless noise when accelerating hard. |
04-08-2015, 02:00 PM | #333 |
The Fail Boat
Drives: CWP S.B.
The real answer is EZ30 swap!! Ok I will show myself out...
04-08-2015, 02:26 PM | #334 | |
Drives: '13 10 Series FRS #1203
The Following User Says Thank You to Shady195 For This Useful Post: | JB86'd (04-08-2015) |
04-08-2015, 03:23 PM | #335 |
Drives: '13 FR-S
It doesn't matter whether it's my Porsche, my BMW or my Scion, I'm always looking for the best. "Harmless" is an assumption ... it just doesn't sound smooth like the VTEC hitting on my Honda's. I've never owned a Subaru before, so that may be what is tripping me out. I've never heard this kind of noise in any German car.
04-09-2015, 04:56 PM | #336 | |
Similar Threads | ||||
Variable Valve "Butterfly" Exhaust | dlux | Southern California | 19 | 02-22-2016 06:21 PM |
First tank OFT E85 tuning. Noise? | Tromatic | Software Tuning | 2 | 02-20-2014 05:43 PM |
Exhaust Cut Off Valve | beagoodruslan | Engine, Exhaust, Transmission | 2 | 01-01-2014 01:47 AM |
Exhaust Noise that goes away after warmed up | FastLane1000 | Engine, Exhaust, Transmission | 10 | 08-15-2013 10:06 PM |
Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
