Old 03-07-2019, 01:38 PM   #15
robotleader
Drives: brzzzz
heavier shift knob
robotleader is offline   Reply With Quote
The Following User Says Thank You to robotleader For This Useful Post:
smg1138 (03-07-2019)
Old 03-07-2019, 01:57 PM   #16
FT86WI
Drives: 2013 Scion FR-S / Firestorm Red
I've had more challenges with getting it into 1st when it's really cold than going from 1st to 2nd. I do a decent amount of 2nd gear starts until my car warms up in the winter as a result.
Living in Wisconsin, I've had this problem with pretty much every manual transmission I've had over the past 20 years. I just always started in 2nd. Never had issues with a clutch, other than the POS Plymouth Neon I learned to drive stick on (went out around 120k miles).
FT86WI is offline   Reply With Quote
Old 03-07-2019, 02:05 PM   #17
FT86WI
Originally Posted by robotleader View Post
heavier shift knob
I was always told heavy shift knobs were bad for syncros. Any truth to that?
Old 03-08-2019, 10:44 AM   #18
nico_rsx
Drives: BRZ 2017 Pure Red, MT
On my second winter the 1-2 shift really improved. I was around 40K km. Still on the stock fluid.
On my first winter, when the shift were still rough, doing a 1-2-1 shift with the clutch pressed before leaving seemed to help oil things up. Also not shifting before 3.5k rpm help.
But the 2 to 1 shift is still as bad. It's almost impossible for me to shift back into first unless the car is at a complete stop. Most of the time I do my first two stops in second gear.
nico_rsx is offline   Reply With Quote
Old 03-08-2019, 03:34 PM   #19
Decep
Drives: 2013 FR-S Series 10
If you are coming to a stop but not quite, try double clutching the 2-1 downshift but without a rev match. its usually butter smooth under 5mph.
Old 03-08-2019, 04:11 PM   #20
churchx
churchx's Avatar
Drives: 2014 GT86
2-1 downshift is on many MT cars speed limited to very low speeds, to prevent accidental money shift with overreving engine too much. Not trait of this particular gearbox, designed in safeguard in many manual transmissions. Rev matching can help get into 1st though even at higher speeds.
Old 03-11-2019, 03:24 PM   #21
nico_rsx
Yes I know, but in the summer I can easily downshift 2-1 while going 2-3 miles/h. When it's really cold, 1mph is still too fast. The wheels need to be completely stopped. After 2 minutes of driving, it's a lot better and I can downshift while still rolling slowly.
Last year I experimented with double clutch and it didn't help, but I could try again.
Edit: By cold I mean 10F and lower.
Old 03-14-2019, 09:55 PM   #22
Decep
Thats normal even in California 40 degree F "cold"
Car won't shift into first gear Longjohnstrokems Issues | Warranty | Recalls / TSB 48 09-16-2019 06:46 PM
LA traffic gear shift mod drz400dude Cosmetic Modification (Interior/Exterior/Lighting) 2 02-22-2017 03:18 PM
Balky 1st gear shift ogrowup Scion FR-S / Toyota 86 GT86 General Forum 26 07-31-2015 12:16 PM
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) -- General Topics 31 03-24-2015 01:50 PM
Gear shift 'step'. -Tom- Cosmetic Modification (Interior/Exterior/Lighting) 1 01-05-2015 03:13 PM
