Old 09-21-2016, 03:04 PM   #71
FX86
i removed both visors because weight reduction and they don't have a vanity light
Old 11-02-2016, 07:25 PM   #72
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
Welp this just happened to me. I'm outside of warranty though, what's the cheapest route to getting a passenger visor mount replaced? Only my mount broke, the visor is fine. '13 FRS.
oldpueblo is offline   Reply With Quote
Old 11-10-2016, 09:45 AM   #73
rkaywhodat
Drives: 2017 Toyota 86 Halo
RIP passenger sun visor in 2017 Toyota 86
rkaywhodat is offline   Reply With Quote
Old 11-10-2016, 02:47 PM   #74
oldpueblo
oldpueblo's Avatar
This is the route I went. $30 free shipping.
http://www.ebay.com/sch/i.html?_odkw...visor&_sacat=0
Old 11-15-2016, 11:35 PM   #75
cycleboy
Drives: 2013 Scion FR-S - Argento
Ebay, and needing a passenger's side you should have more availability since most that break seem to be driver's side. I went without for awhile due to that and it sucked. Sun in the eyes = bad!
cycleboy is offline   Reply With Quote
Old 11-19-2016, 08:36 PM   #76
root
Drives: Raven FR-S
Both of mine have broken. Right side was the doohickey inside the visor that the shaft spins on shifted. I got replacement from dealer. A few weeks later the left drivers base cracked like as seen in this thread. I have yet to attempt to take the base from passenger and put on drivers. Its not exactly the same but looks close enough it might work. But the base might crack trying to remove and install that piece, it isn't really designed to be removed.
root is offline   Reply With Quote
Old 11-30-2016, 12:28 PM   #77
luluma
luluma's Avatar
Drives: 2013 Scion FRS
anyone have a part numbers for the base?
luluma is offline   Reply With Quote
Old 12-01-2016, 02:30 AM   #78
oldpueblo
oldpueblo's Avatar
I was told by Toyota that the entire thing is one part, base and visor.
Old 12-07-2016, 09:23 AM   #79
rkaywhodat
Just wanted to report back had my17 passenger sun visor repaired under warranty in Canada, no hassle.
Sent from my D5803 using Tapatalk
Old 07-04-2018, 09:44 PM   #80
Simok
Drives: 2013 FRS
Driver side broke around 25k, replaced under waranty. Now at 45k passenger broke, had to eat the cost and buy a new one. Installed it and 2 days later drivers side broke again. Has anyone found a good epoxy or glue that works? I tried a 2 part gorrilla glue (similar to jbweld) and the glue just peeled right off and didnt do anything.
Simok is offline   Reply With Quote
Old 07-05-2018, 01:30 AM   #81
Impureclient
Drives: 2015 FR-S
Mine is still good so far but after reading all this somebody should make a steel/aluminum version base to swap in there. I never looked to see how it's put together but can you just
break the plastic off and replace it like that? Also has anybody tried taking one from another car and bolting it up there if it has the same two screw in the same spot?
I found this: https://www.thingiverse.com/thing:2522820 Have no idea what to do with that but can't that be used to create a metal version?
Impureclient is offline   Reply With Quote
The Following User Says Thank You to Impureclient For This Useful Post:
Suparu (08-23-2019)
Old 05-14-2019, 06:20 PM   #82
JimR
JimR's Avatar
Drives: '15 FR-S, '92 Sentra SE-R
Just a bump: I tried the Thingverse 3D print linked above for the visor mount. They have a "Craftcloud" printing service that selects the cheapest vendor for what you want.
I ordered one in black nylon and received it six days later for $10.68 shipped. Rough texture, but no one would notice unless you pointed it out. We'll see if it lasts very long.
JimR is offline   Reply With Quote
The Following User Says Thank You to JimR For This Useful Post:
Suparu (08-23-2019)
Old 08-23-2019, 07:14 PM   #83
Suparu
Drives: 2013 BRZ Limited
My passenger side one broke after using the sun visors to hold a sun shade for just a month. Very frustrating.
Thanks Impureclient & JimR. I just ordered that Thingiverse 3D printed part in black finished nylon from Craftcloud. I ordered 2 of them (total $25 including shipping) so it’ll match on each side. I’ll post when I receive them and install them.
Suparu is offline   Reply With Quote
The Following User Says Thank You to Suparu For This Useful Post:
bcj (08-24-2019)
Old 08-23-2019, 11:18 PM   #84
Decep
Drives: 2013 FR-S Series 10
my passenger mirror feels fine but my driver side feels stiff and i've not much confidence in it lasting much longer.
Hate those ugly visor warnings? avusblue Cosmetic Modification (Interior/Exterior/Lighting) 28 12-17-2014 03:16 PM
Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR nigel-jdmparts Interior Parts (Incl. Lighting) 89 02-01-2013 04:00 PM
Visor Warning Label Removal poudre Cosmetic Modification (Interior/Exterior/Lighting) 28 09-19-2012 08:16 PM
Limited Sun Visor Removal poudre BRZ First-Gen (2012+) -- General Topics 7 07-08-2012 03:49 PM
N1 Spec Visor Sticker GodSays Scion FR-S / Toyota 86 GT86 General Forum 13 03-04-2012 03:22 PM
