07-09-2018, 01:15 PM | #169 | |
Drives: 22RE, FA20, 4G63
/\ This Sent from my iPhone using Tapatalk |
07-10-2018, 11:10 PM | #170 |
TRD supercharger
12.5:1 built motor, lots of other stuff ~9psi. This is the largest pulley, I have 3 smaller ones. Very conservative tune on E50, will tune more aggressively once there are more miles on the engine. Ignore some of the mess in the engine bay, still very much a work in progress. |
The Following 5 Users Say Thank You to xwd For This Useful Post: | ATL BRZ (12-17-2018), CSG Mike (07-27-2018), eherschend (07-13-2018), Somerandom18 (07-28-2018), weederr33 (12-28-2018) |
07-10-2018, 11:42 PM | #171 |
Wes
Trd supercharger? Where did that come from
Instagram: @gt86ws
07-27-2018, 09:54 PM | #172 |
Drives: 2014 Scion FR-S
Can someone please explain this?
How does this dyno graph go backwards? wtf
Its from this video: [ame]https://www.youtube.com/watch?v=mcUsV7fE4Bs[/ame] |
11-19-2018, 12:24 PM | #174 |
Drives: GT86
- Cosworth Supercharger 2.0 on 98RON map,
- 102RON fuel in the tank - not sure about the boost values, no smaller pulley, - stock engine, stock exhaust, Cosworth Air Filter, Last edited by eMCee; 12-28-2018 at 11:20 AM. |
The Following 2 Users Say Thank You to eMCee For This Useful Post: | 86TOYO2k17 (02-29-2020), sly (11-20-2018) |
12-11-2018, 03:32 PM | #175 | |
Drives: brz
please update?
12-11-2018, 03:53 PM | #176 |
I Love custom Turbo kits
Drives: Limited BRZ
I don't know wat google did but they f'd up a bunch of my pictures....
The car made right at 300 whp that day. It's vastly different now with a V8 swap.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | CSG Mike (12-11-2018) |
12-16-2018, 09:14 PM | #177 |
TRD SC update. Went from a 100mm pulley to 95mm, gained about 40hp and 30ft-lbs, peak was around 11.5psi. I have 90, 85, and 80mm pulleys left still. I think the highest run of the day was 347/268. This is on E75.
12-26-2018, 11:45 AM | #178 |
Drives: '13 with go fast bits attached
-Edelbrock Supercharger
-92 Oct Pump gas -Stock Pulley -Gruppe S UEL header, ECUTek tune, Magnaflow Catback -Note : Clutch began slipping before tuning was complete. Blue line is headers and tune only. Will update after clutch and re-tune. |
The Following User Says Thank You to diluzio91 For This Useful Post: | Side (10-02-2020) |
12-28-2018, 09:58 AM | #179 |
Drives: Toyota 86 Turbo, Lexus NX300H
-SBD 500x turbo kit
-100ron / all stock fuel system - red : 12psi , blue: 11psi - 2.25 exhaust with 1 cat , dual catch can, turbosmart EBC , ORC clutch, STI maf sensor - 4th gear pull , self tune via OFT - stock 86 made 170WHP on same dyno.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
12-28-2018, 10:17 AM | #180 |
Drives: brz 2017 hksv2
@Yobiwan , you had the hks v2 with 45mm restrictor, why the change?
The Following User Says Thank You to tomm.brz For This Useful Post: | Yobiwan (12-28-2018) |
12-28-2018, 04:08 PM | #181 | |
I just want to know difference between HKS supercharger and SBD 500x. I feel 500x is better in every aspect of driving and make more power at same psi than HKS supercharger. My best dyno number with hks v2 was about 270 whp
The Following User Says Thank You to Yobiwan For This Useful Post: | tomm.brz (12-28-2018) |
12-28-2018, 04:31 PM | #182 |
Cool happy for You
I m waiting to install the hks v2 (the new one with black housing arrived to me last week) with 44mm Can you please post the dyno of Your hks kit You had here for me? Are those wheel hp right? |
Similar Threads | ||||
Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 07:00 PM |
Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 10:28 PM |
Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 08:06 AM |
