Old 05-02-2015, 06:53 PM   #141
NonStopTuning
NonStopTuning's Avatar
Drives: AE86
Who else has pics?!
NonStopTuning is offline   Reply With Quote
Old 05-07-2015, 07:12 PM   #142
bryan chaffee
Drives: 2012 toyota tacoma
Pictures?
Although I drive a Tacoma with these NST pulleys I will still post a picture, NST pulleys are top quality product. I've been running mine on my tacoma for over 30k miles now, NO problems @ all. Throttle response is slightly better, although I have not dyno'd it the seat of my pants tells me these pulleys are good for 5-10 horses. Warning- these can take some time to get as usually they are made custom per order - but if you are okay with the wait, there is no comparison between NST and other pulley companies, the quality is unparalleled.
bryan chaffee is offline   Reply With Quote
Old 05-08-2015, 05:01 PM   #143
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
It took me months to get my refund - stay persistent and good luck!
nlowell is offline   Reply With Quote
Old 05-10-2015, 12:23 AM   #144
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by NonStopTuning View Post
Yes, we've had the idler/tensioner pulleys in the works for a while.
Thanks!
Will this still going to happen?
Thanks.
cslntuee is offline   Reply With Quote
Old 05-13-2015, 03:41 PM   #145
NonStopTuning
Drives: AE86
Bryan, I'm sorry to read about your case and I've emailed you again on your issue. Let's keep this to email moving forward please.
Old 05-13-2015, 03:42 PM   #146
NonStopTuning
Drives: AE86
Thanks.
Yes, this is still in the works.
The Following User Says Thank You to NonStopTuning For This Useful Post:
cslntuee (05-23-2015)
Old 05-23-2015, 02:32 PM   #147
NonStopTuning
Drives: AE86
http://nonstoptuningusa.com/2014/10/...-dyno-testing/
DC2R (05-24-2015)
Old 05-27-2015, 11:57 AM   #148
NonStopTuning
Drives: AE86
FRS / BRZ kits are in stock in five colors and ready for immediate shipping.
Red, blue, gold, purple, black.
Thanks all!
Old 06-01-2015, 04:50 PM   #149
NonStopTuning
Drives: AE86
Any new NST pulley owners?!
Old 06-09-2015, 11:42 PM   #150
NonStopTuning
Drives: AE86
This thread needs more
Old 06-18-2015, 12:08 PM   #151
NonStopTuning
Drives: AE86
Anyone else?
Old 06-18-2015, 08:00 PM   #152
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
@NonStopTuning
I seem to have a rather small oil leak. This wouldn't be such an issue if it didn't make a squeaking sound every time it leaks a bit. I've just re-torqued the bolt, and it has the original o ring. Still making the sound and presumably still spreading oil everywhere.
JohnJuan is offline   Reply With Quote
Old 06-18-2015, 08:09 PM   #153
NonStopTuning
Drives: AE86
Not good I've never heard of this issue with the FRS/BRZ before.
How many miles on the engine?
Apx how many miles when the crank pulley was installed?
The OEM crank bolt is considered a one-time use item. Using the same bolt on a relatively low mileage motor is not a big deal and is what most customers do. But on a higher mileage engine the factory manual calls for the use of a new crank bolt and oil seal/sleeve. I would start there and add a new belt while you're at it.
I hope that helps.
DC2R (07-24-2015)
Old 06-18-2015, 09:07 PM   #154
JohnJuan
JohnJuan's Avatar
32k
23k
I hope that helps.
Looks like I'll be digging through some parts lists. I was first thinking maybe just a thicker o-ring. It did start doing this just after I installed it, and a dealer tech sprayed the belt with belt dressing, which made the squeak go away for a little while, but it has gotten more frequent as the weather has warmed up.
Also, I definitely did get the pulley lined up correctly and the o-ring in there. There were a couple people who had issues with that, and I made sure not to join them.
AST 5200 Dampers Updated 25th Feb DYNO CHARTS ADDED Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 12-17-2015 05:06 AM
NonStopTuning FRS BRZ Pulley Kit Group Buy NonStopTuning Groupbuys 8 05-23-2015 02:27 PM
NonStopTuning 3 piece Pulley Kit - RED harkbrz Canada Classifieds 4 11-01-2014 12:12 PM
NonStopTuning Short Shifter, Info, Ideas, Feedback thread NonStopTuning Engine, Exhaust, Transmission 5 10-23-2014 10:38 PM
Run in method Dyno charts Surok AUSTRALIA 0 10-07-2012 11:29 PM
