03-24-2014, 02:08 PM | #4005 |
Drives: 2013 SWP BRZ RP Turbo Kit
Is nameless advertising the coating as a thermal barrier or just a ceramic coating? They are two different things as I found out when researching coatings for our products.
The Following User Says Thank You to Revolutions Performance For This Useful Post: | FrsDuke (03-24-2014) |
03-24-2014, 02:11 PM | #4006 | |
Fanboy
Drives: 2013 ultramarine frs
"Optional ceramic coating is the best in the business - featuring a two layer, twice cured process that radically reduces surface temperatures and heat transfer out of the tubing while at the same time improving exhaust gas velocity by retaining heat inside of the header. Both layers of coating are on the inside and outside of the tubing (so if you cross sectioned the tube, it'd be two layers of ceramic, one layer of stainless, two layers of ceramic). It is highly recommended for performance, longevity in salted/corrosive environments as well as overall reduction in engine bay heat. As a reference, this is what people coat turbine housings with. It's the most aggressive and resilient coating on the market, bar none. " What has me pondering things is a number of buyers with the coating voicing concerns and it being black. Figure I'd just give folks the chance to compare.
I'm done helping those who won't help themselves.
TL;DR: -Duke |
03-24-2014, 02:17 PM | #4007 | |
Drives: small
The reasoning for improving gas flow is by using the insulation to retain high temps already present to retain higher port velocity. If the heat is retained in the gas, it is not being lost as ambient temperature under the hood as with an uncoated header. Basic laws of Thermodynamics prohibit the coating from creating more heat than is already present when untreated. Your theory is basically that all race teams that use coated headers are spending more time and money to actually make their cars slower? Maybe this will help: http://www.carcraft.com/techarticles...amic_coatings/ |
The Following 2 Users Say Thank You to Boxer486 For This Useful Post: | chanomatik (03-24-2014), Revolutions Performance (03-24-2014) |
03-24-2014, 03:14 PM | #4008 | |
Fanboy
Let me rephrase my entire line of inquiry. Let's find out just how awesome the ceramic coating really is! I got uncoated numbers above lets see some coated numbers.
TL;DR: -Duke |
03-24-2014, 03:28 PM | #4009 | |
That guy
Drives: Ultramarine mt FR-S
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
03-24-2014, 04:07 PM | #4010 |
Fanboy
Again I'm not saying ceramic coating doesn't work. I want to know how well the coating on the nameless header works
TL;DR: -Duke |
03-24-2014, 04:15 PM | #4011 |
My coating on my header definitely reduces temps. I compared how hot my end of my overpipe was to my front pipe and it was significantly cooler. Coating has been used for many many years. It also helps against cracking in the later years from long term high heat exposure.
03-25-2014, 11:41 AM | #4012 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
The Following User Says Thank You to Ranatsu For This Useful Post: | FrsDuke (03-25-2014) |
03-25-2014, 11:43 AM | #4013 | |
Drives: Attitude
How could we forget? Grueling endurance testing in the deserts of Arizona! |
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | chanomatik (03-25-2014) |
03-25-2014, 11:54 AM | #4014 | |
Drives: GT-86
black doesnt radiate more heat it actually absorbs. |
03-25-2014, 11:59 AM | #4015 |
Drives: 2013 Asphalt FRS
Coating producing more heat. That's why people use it. More heat soak more power...
Just kidding.......
2013 Sion FRS
2014 Subaru WRX 2014 Subaru XV |
03-25-2014, 11:59 AM | #4016 |
Cone basher
I'm mostly comparing to what he was getting. I've checked before in the past at Autocross events and I feel like the intake was around 120 or so if just sitting at idle in grid.
03-25-2014, 12:28 PM | #4017 |
Drives: Attitude
03-25-2014, 12:34 PM | #4018 |
Drives: 2013 WRB BRZ Limited
I'm on the waiting list for the next batch of coated headers, so when I get mine if we're still debating this I'll grab pre-install stock un-coated header temps and post install coated header temps.
Tags |
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
Similar Threads | ||||
Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
