Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-20-2019, 01:29 AM | #1 |
Drives: Scion Frs
Help installing Overpipe
Hey guys so I’m about to install my Tomei Overpipe soon and I was just wondering if you guys could break down for me how to install it the proper way. If there’s a diy thread for this feel free to link. Thanks I appreciate it guys!
09-20-2019, 02:11 AM | #2 |
Youtube it mate
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
09-20-2019, 02:58 AM | #3 |
Drives: 2013 frs red
Big hammer. In all seriousness there are some YouTube videos detailing the installation.
09-20-2019, 03:39 AM | #4 |
Pull the engine mount bolts
The Following User Says Thank You to 86MLR For This Useful Post: | NoHaveMSG (09-20-2019) |
09-20-2019, 01:16 PM | #5 |
Wheels for Brains
Takes some serious tetris.
Need to remove heatshield from stock overpipe. Otherwise, you'll need to lift the engine a bit |
The Following User Says Thank You to EndlessAzure For This Useful Post: | juniorrr (09-21-2019) |
09-20-2019, 04:38 PM | #6 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
You actually don't need to lift the engine. You can rotate the piping and finagle it over the subframe once you've taken the heat shielding off. Though taking the headers off or the front pipe off significantly helps. Otherwise, yeah you might need to jack the motor. As for the rest of the install, it's seriously unbolting something and then bolting it back in.
The Following User Says Thank You to weederr33 For This Useful Post: | juniorrr (09-21-2019) |
09-20-2019, 06:13 PM | #7 |
Drives: 2017 BRZ PP , 2005 Saab 97X
best way I was able to do this
jack car up. secure with wheel chocks find the engine mount bolts to lower subframe, loosen and back off but do not remove completely take floor jack on a wide 2x6 and jack up on oil pan. remove over pipe, and place into position new overpipe. let engine back down and tighten move overpipe into position and tighten down. thats how i did it easy day and no worries about the engine moving too much. the nut threaded on the bolt will prevent you from remving it too much |
09-22-2019, 07:35 AM | #8 | |||
Drives: Scion Frs
09-22-2019, 02:04 PM | #9 |
Wide piece of wood on the oil pan. The oil pan is steel and you aren't hitting it with force. Just lifting it up a smidge. And it'll be fine.
09-22-2019, 06:36 PM | #10 |
Drives: GTS 86
Use this tip: try doing it from the front of the car to the back. I have installed several of them with no issues whatsoever. If is one of those big fck off one, like 2.75 or 3", loosen the engine mounts bolts and lift the engine up a little. Use a piece of timber to lift it by the oil pan.
Good luck bro! |
Similar Threads | ||||
WTB - 3" overpipe & Perrin 2.5" overpipe for sale | DAN_BRZ | Canada Classifieds | 1 | 02-27-2015 01:15 PM |
which is better the p&l overpipe or motiv overpipe | Anthony7515 | Engine, Exhaust, Transmission | 15 | 04-08-2014 07:00 AM |
Installing Overpipe Question | TONY_BRZ | Engine, Exhaust, Transmission | 13 | 03-19-2014 12:46 AM |
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! | MotivConcepts | Engine, Exhaust, Bolt-Ons | 96 | 07-19-2013 02:03 AM |
need help installing this | chenshuo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-14-2013 01:17 PM |
