Scion FR-S / Toyota 86 GT86 General Forum The place to start for the Scion FR-S / Toyota 86 | GT86 |
08-15-2014, 01:38 PM | #1 |
Drives: Manual Argento FR-S named Scyris ;)
Gas Pump Problem
Hi guys!
New to posting here but I have a problem that I can't for the life of me figure out. I have a first gen FR-S. Over the past couple months when I am at the gas station trying to fill up the tank the gas nozzle prematurely clicks. It started of doing it a couple times all the way gradually up until now a couple months later it constantly prematurely clicks several times and now gas shoots back out of the car repeatedly. It's a complete nightmare to have to get gas. I know for a fact my tank is never filled when I stop to get gas, have tried different pumps as well as different gas stations entirely to end up with no resolve. Any ideas on what the problem is and any suggestions? Thanks so much! :o Sakina |
08-15-2014, 01:43 PM | #2 |
Drives: 2013 GBS BRZ Limited
The hose from the filler to the tank is kinked.
I have a borescope from Home depot that you could look down the tube and see. Maybe you could stop by the local HD and ask them to demo their shelf model. I think it's RYobi. |
08-15-2014, 04:05 PM | #4 | |
cut & paste from the manual: "13. Disconnecting the fuel tank to filler pipe hose (1) Loosen the hose clamp, and disconnect the fuel tank to filler pipe hose." |
08-15-2014, 04:10 PM | #5 |
Spun
Drives: 17' Focus RS
08-15-2014, 04:15 PM | #6 |
Drives: 2014 Ultramarine 6MT FR-S Monogram
Looks like warranty time.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
08-15-2014, 06:07 PM | #7 |
Drives: 2014 BRZ Limited
Known issue. The rubber hose in the fuel filler has collapsed. The dealer will replace it under warranty if your mileage is still low enough.
Here's someone else with the same problem: http://www.ft86club.com/forums/showthread.php?t=61043 |
The Following 2 Users Say Thank You to extrashaky For This Useful Post: | strat61caster (08-15-2014), W2 (08-15-2014) |
08-15-2014, 06:41 PM | #8 | |
77213B SU00301093 HOSE, FUEL TANK TO FILLER PIPE SCION FR-S (ZN6); BASE,HI,STD Last edited by Tromatic; 08-15-2014 at 06:55 PM. |
08-15-2014, 09:29 PM | #10 |
Thanks so much for the responses guys appreciate it much!!!
08-15-2014, 09:30 PM | #11 |
Similar Threads | ||||
Max NA HP on pump gas as of now? | jadewbj | Engine, Exhaust, Transmission | 128 | 02-17-2016 09:28 AM |
AFR Problem (maybe Fuel Pump installation bad) | whitefrs | Engine, Exhaust, Transmission | 37 | 08-30-2013 02:36 PM |
Vac Pump | sw20kosh | Engine, Exhaust, Transmission | 1 | 06-06-2013 07:46 PM |
What gas do you pump? | its_the_biz | Scion FR-S / Toyota 86 GT86 General Forum | 45 | 02-27-2013 11:22 PM |
Be careful at the pump with E15 | Thunderchicken | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-10-2012 10:33 PM |
