Old 03-27-2024, 10:52 AM   #57
jflogerzi
jflogerzi's Avatar
I did, but ended up buying and installing your old CSP’s.
oh yea
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
NoHaveMSG (03-27-2024)
Old 03-27-2024, 01:59 PM   #58
RedReplicant
Drives: None
They are not adjustable with the RCE/KW’s that I am aware off. I have them set to not touch with the Annex’s.
Edit: Now that I am thinking about it I could probably double stock bumpers or make a rubber puck to limit up travel.
Painful to lose out on bump travel
But yeah, I've noticed these cars are very, very sensitive to ride height. Over simplifying for making small balance changes but front for entry characteristics, rear for exit.
If you get the front too low it'll turn in stupid fast but then push mid corner.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Old 03-28-2024, 04:20 PM   #59
Bergycheese348
Bergycheese348's Avatar
Drives: TRD Supercharged 2016 FR-S
I am not a specialist, but this talk about ride height now has me understanding why the TRD coilovers they had (the yellow ones) never really dropped ride height that much. They always just seemed to be way too tall...
"Ooh, hang on. That is the throb of a turbocharged flat four engine. A sound which, all over the world, heralds the imminent arrival of a moran" -Jeremy Clarkson
T RD, Verus, Ace
Bergycheese348 is offline   Reply With Quote
Old 03-28-2024, 04:23 PM   #60
RedReplicant
Drives: None
I have Xidas which have a pretty short stack height in comparison to a lot of other setups. When I was messing with geometry last year it seemed like a lot of people have to have very, very little bump travel given what my travel numbers, wheel position at the bump stop, and ride height look like.
I've also noticed there are people that run a big rear bar or big spring rate stagger with the car low and there are people that have a more square setup with a stiffer front bar and soft rear bar.
Old 03-28-2024, 04:46 PM   #61
RT-BRZ
FNG
RT-BRZ's Avatar
Drives: 2013 Subaru BRZ
I run Shaftworks and Jon Lugod said set them so the pinch welds are 5.5" of the ground. That's definitely higher than they were when I had Feals. The car works great like that though.
RT-BRZ is offline   Reply With Quote
Old 03-28-2024, 05:07 PM   #62
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
I run my Shaftworks with only a 20mm drop. I would be curious now about the pinch weld measurement.
My experience mirrors that of yours in terms of feel. I love how it soaks up the bumps on the road. Nothing seems to phase them
autoracer86 is offline   Reply With Quote
The Following User Says Thank You to autoracer86 For This Useful Post:
RT-BRZ (03-28-2024)
Old 03-28-2024, 08:14 PM   #63
RT-BRZ
FNG
RT-BRZ's Avatar
Definitely pull the measurements if you don't mind. I'm curious now too.
Yeah, the car rides great on the track. It just feels planted without feeling like I'm in a shopping cart on pavement.
The Following User Says Thank You to RT-BRZ For This Useful Post:
autoracer86 (03-28-2024)
FS: SARD LSR Style Carbon wing **wing only* brzzy Canada Classifieds 3 03-23-2017 09:58 PM
Does anybody have seibon gt wing or apr gtc200 universal wing on their car? spicyricecake Cosmetic Modification (Interior/Exterior/Lighting) 6 03-17-2016 08:38 AM
FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney Enalband24 Exterior Parts (Aero, Lighting, Etc.) 10 01-03-2016 12:24 PM
Gauging Interest: Wing or GT Wing?! awang0528 Exterior Parts (Aero, Lighting, Etc.) 3 05-01-2013 12:12 AM
