10-24-2017, 09:50 AM | #3431 | |
Your front camber is lacking and you will have to be careful on corner entry to not over drive the front grip you have available. More front camber will allow you to go deeper into the corner so to speak and power out harder. Don't over think it, just go drive it, you have a fun setup on your hands, when you feel like the car is holding you back have a fast driver get in it and show you what's still left in the car you're not using. A stiffer front bar reduces the pain of not having enough camber as well, not by much but by a little. |
The Following User Says Thank You to strat61caster For This Useful Post: | ApexEight (10-24-2017) |
10-24-2017, 01:44 PM | #3433 |
Drives: 2013 BRZ automatic
I would love to get rid of those cockamamie mounting points on the struts but in order for the sway bar to have correct leverage, it needs to be tied to suspension movement at the outboard end of the control arm. Connecting to near the inner end of the LCA would render the sway bar nearly useless.
10-25-2017, 12:25 AM | #3434 | |
My current alignment settings are: Front:
The Following User Says Thank You to RJasonKlein For This Useful Post: | ApexEight (10-25-2017) |
11-02-2017, 08:59 PM | #3435 |
Drives: Subaru BRZ
ap sprint kit here, is hawk dtc30 a good match with re71r and kwv3? using hp+ at the rear. -3.2F -2.4R
11-03-2017, 08:37 AM | #3436 | |
Drives: 2017 BRZ
I like the Carbotech AX-6 I've been using. Really impressed with a drive on Winmax W3 as well (note, not with Sprint kit). Autocross and street for me, the guy with the W3 also does some track days in think... Assume he'll step up to more pad at some point for track. Do keep the same pads on both ends. |
11-17-2017, 09:16 PM | #3437 |
Looking for advice on what to do for suspension.
I currently have Koni inserts, rce tarmac springs, hvt front plates and oem rear mounts. This setup has about 80,000 miles on them and I feel like they’ve lost “something”. I figure these Konis are almost done and I want to upgrade. For my next setup my main concern is going to be comfort. The roads around me are getting bumpier every year. Knowing this would you guys recommend swapping out the Konis for Bilstein b6 or replace everything with tein flex A? I have heard that the flex A is comfortable and I’d only drop it 20mm or so. The bilsteins have a great reputation for performance however. |
11-17-2017, 11:45 PM | #3438 |
Drives: 2023 BRZ
Why not Bilstein B16? It sounds like we have similar priorities. That's what I ordered.
The Following User Says Thank You to Pat For This Useful Post: | strat61caster (11-18-2017) |
11-18-2017, 05:10 PM | #3439 |
11-18-2017, 06:59 PM | #3440 |
Drives: 2023 BRZ
Based on my research I expect that's it. If not, it's close.
11-19-2017, 03:10 PM | #3441 |
The B16 seems ideal, it’s just the price that’s holding me back.
I could do b16: $1,900 Or b8 + sti rear top hats + whiteline control arms + Federal RSR/RR + track day all for $120 cheaper... My friend has Ohlins on his GR sti and they are comfortable but I don’t know if I’d really get the max benefit of dual adjustability. I look at it like golf drivers with adjustments on the head. You better already have a perfect swing before you step up to something like that |
11-21-2017, 01:49 PM | #3442 |
Drives: 2023 BRZ
Call Andy or Myles at RCE and ask them about what a set of B16s might cost. It's worth a phone call just to be sure.
The Following User Says Thank You to Pat For This Useful Post: | Racecomp Engineering (11-21-2017) |
12-02-2017, 06:37 AM | #3443 |
Drives: 2015 Scion FRS
Set Up Question? I'm getting ready to install some RCE Tarmac 2 coilovers on my 15 Frs. I'm lowering about an inch from stock height. Should my end link length change because of the lowering. 'Im going to adjustable end links. I'm (wild guessing) thinking of going a bit (1/4 in.) shorter in rear and 3/4 in in front. Any help on this one. Thanks for the forum!
12-02-2017, 10:00 AM | #3444 | |
Fronts will probably need to be adjusted, rears might not need much. - Andrew |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | bdtbdtbdt (12-02-2017) |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
