Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
09-01-2019, 02:41 AM | #15 |
09-01-2019, 08:26 AM | #16 |
When the rubber coupler that connects the EPS motor to the worm gear wears out it will be metal to metal and makes a very similar chatter when doing moderate braking. If it’s the EPS coupler you should also hear it when not braking when going low speed over high frequency bumps like road reflectors or a dirt road. If you are getting a little knock on reflectors then my money is on the EPS coupler. It’s under $10 to fix if you are willing to DIY and have very basic tools. |
The Following 2 Users Say Thank You to ermax For This Useful Post: | humfrz (09-01-2019), Ultramaroon (09-01-2019) |
09-01-2019, 08:38 AM | #17 |
09-01-2019, 08:39 AM | #18 | |
09-01-2019, 08:41 AM | #19 | |
If it’s the EPS the sound will come from right behind the gauge cluster down around tour feet. You can actually reach your hand up under there and put your hand on the motor. Here is a DIY for the fix: https://www.ft86club.com/forums/showthread.php?t=133606 |
09-01-2019, 08:44 AM | #20 | |
The Following User Says Thank You to rabbit86_ For This Useful Post: | ermax (09-01-2019) |
Similar Threads | ||||
2600rpm vibration | stueck9356 | Issues | Warranty | Recalls / TSB | 3 | 03-06-2014 12:06 PM |
Speaker Vibration | JayNutter | Electronics | Audio | NAV | Infotainment | 12 | 07-31-2013 12:24 AM |
Exhaust vibration/rattle at cold start? | Foobar | Engine, Exhaust, Transmission | 7 | 04-16-2013 05:15 PM |
Door Speaker Vibration | MattM232 | Issues | Warranty | Recalls / TSB | 16 | 03-19-2013 07:03 PM |
Rattle When Braking Between ~25-17mph | GhostofAkina | Issues | Warranty | Recalls / TSB | 9 | 11-12-2012 11:49 AM |
