02-07-2017, 01:59 PM | #15 |
The Gunshine State
Drives: '14 BRZ Limited
I've always loved the 4G63 and SR20 when it came to 4 bangers.
Current DD: M235i |
02-07-2017, 02:00 PM | #16 | |
Drives: 2005 Toyota Camry
I strongly suggest you to look up what is done to that engine, and whether or not you have around $20-50k lying around to rebuild your engine when it goes bad. -alex |
The Following User Says Thank You to mav1178 For This Useful Post: | KR-S (02-09-2017) |
02-07-2017, 02:05 PM | #17 |
Drives: 2013 Scion FR-S, 2014 Scion tC
Isn't like I'm getting upto 800 right off the back, I just wanna have a great weekend drift car that I can still drive to work on Monday.
02-07-2017, 02:46 PM | #18 |
02-07-2017, 03:00 PM | #19 |
About 500 just for fun, but now just thinking about keeping the the FA and going the Crawford Performance route.
02-07-2017, 03:49 PM | #20 | |
Dismember
Drives: 2013 Red Scion FR-S
Have you even swapped before, bro?
02-07-2017, 03:52 PM | #21 |
Drives: 2015 Subaru BRZ WRB
2 Things.
1. Fuck Mike Kojimas well researched opinions. 2. If you think you need power to drift you are doing it wrong. |
The Following User Says Thank You to irax For This Useful Post: | itsjustdavep (03-24-2017) |
02-07-2017, 04:44 PM | #23 |
Drives: 2013 BRZ DGM
If 500hp is your goal and you're willing to swap in an engine, you start by looking at engines that are making as close to 500hp as possible to begin with. That way you have one task i.e. swapping the engine and not two i.e. build an engine and swapping it
02-07-2017, 05:36 PM | #24 | |
Drives: 2001 Impreza 2.5 RS
Also, I have a Celica All-Trac with a 3S, a lot of people forgot about those cars...much better than MR2
Colin Beck
02-07-2017, 06:00 PM | #25 |
02-07-2017, 08:23 PM | #26 |
Dismember
That 800HP engine is as stock as something that is not stock at all.
02-07-2017, 09:50 PM | #27 |
Toyota and I have different views on what an engine bay should look like.
Colin Beck
02-08-2017, 03:48 AM | #28 |
Drives: '06 AM V8V Coupe
The 2AR is actually a really good engine. The guy who pioneered the 2GR swap kits for MR2s (Gouky) put one in his AW11 and is now putting one in a ZZW30.
They are a little on the heavy side at 320lbs with all accessories, but IIRC the FA20 is even heavier than that. With a balance shaft delete you are looking at close to 300, which is not bad. They are underrated and make around 170whp stock, and if you switch the header out they get to nearly 200whp. They are extremely insensitive to oil temp and have the excellent 3 stage oil pump which avoids bypassing as much oil. Gouky said he ran his with the factory Rav4 oil to water heat exchanger and the engine was totally fine with the oil at 300F during thousands of miles of racing. You can stroke it with the 1AR crank to 2.7L with basically no weight penalty. What I would do on the FRS is probably stroke it with the 1AR crank, drop some stiffer valve springs in so it can rev higher, then add forged pistons to increase the compression ratio. You would shed a little bit of weight, gain a huge amount of torque, and end up with probably around 260bhp, while keeping the car NA and very reliable. Of course, this would be quite expensive to do, but it would be fun. |
The Following User Says Thank You to serialk11r For This Useful Post: | fguadamuz (03-12-2017) |
Tags |
2arfe, 4 cylinder, daily driver, frs, swap |
