02-04-2016, 01:11 AM | #309 | |
Drives: 2015 Scion FRS, Firestorm
I didn't have any issues after swapping mine, but I had initially adjusted it level to the brake pedal beforehand. Sent from my LG-D800 using Tapatalk |
02-04-2016, 01:23 AM | #310 | |
義理チョコ
If you haven't already adjusted the pedal travel, get in there and play with that. IMO, it's important to get comfortable with clutch adjustment and what it can do for driveability.
02-04-2016, 01:32 AM | #311 | |
義理チョコ
The slave cylinder has no effect on the pedal travel; self-adjusting hydraulic system.
02-18-2016, 08:53 PM | #312 |
Drives: 14 BRZ Limited
Im in NW Ohio and I plan on doing this mod tomorrow. As a mechanic I second or third or whatever number I am saying its a simple job and I would be willing to help anyone in the Ohio, Michigan, Indiana region....I just like road trips.
The Following 2 Users Say Thank You to angadam For This Useful Post: | Ultramaroon (02-18-2016), xsl27x (02-18-2016) |
04-26-2016, 11:56 AM | #313 | |
Drives: '13 BRZ
04-26-2016, 01:40 PM | #314 | |
義理チョコ
Either way, the touch/catch point will rise, not dramatically but it's noticeable.
The Following User Says Thank You to Ultramaroon For This Useful Post: | tobin (04-26-2016) |
04-29-2016, 10:57 PM | #315 |
Drives: Black Panda BRZ
So, anyone else f*cked this up yet? Everything seemed to go well but I have a pedal that just stays stuck to the floor and needs pulling up. I've bled brakes before after fitting new hoses but obviously cocked something up here. How much of a hassle is a bench bleed?
04-29-2016, 11:39 PM | #316 | |
義理チョコ
04-30-2016, 11:45 AM | #317 |
Nope. See if you can guess what I did?
Sent from my Nexus 5 using Tapatalk |
04-30-2016, 01:49 PM | #318 | |
義理チョコ
I'll guess you forgot to use both bolts in the slave so it swung sideways.
04-30-2016, 07:50 PM | #319 | |
*edit - now got the clutch height sorted, feels awesome, the way it should have been stock. Best mod so far without a doubt. Last edited by jonboy99; 04-30-2016 at 09:24 PM. |
The Following User Says Thank You to jonboy99 For This Useful Post: | Ultramaroon (04-30-2016) |
04-30-2016, 11:46 PM | #320 | |
義理チョコ
05-01-2016, 12:44 PM | #321 |
No, didn't bother. Maybe I should sometime, but the boot definitely didn't feel under any pressure - easy to squash so not full of fluid. I'll do it next time i'm in a maintenance mood.
05-22-2016, 10:26 AM | #322 | |
Drives: '13 BRZ
OP: Pedal down, loosen valve, tighten valve, pedal up ck-GT86: loosen valve, pedal down, tighten valve, pedal up |
Tags |
clutch line, slave cylinder |
Similar Threads | ||||
Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 06:31 PM |
Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 08:14 PM |
Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 10:22 AM |
Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 01:24 PM |
Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 05:32 PM |
