07-27-2015, 10:48 PM | #211 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
@Ultramaroon do I just go to Autozone and give them the Subaru part number or do I saw something else to them?
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
07-27-2015, 10:53 PM | #212 | |
義理チョコ
The Following User Says Thank You to Ultramaroon For This Useful Post: | stockysnail (07-28-2015) |
07-28-2015, 05:33 PM | #213 |
Just the tip
Much cheaper than from Subaru and their parts!
07-28-2015, 10:36 PM | #214 |
義理チョコ
If you go with the NAPA one, the casting will have the same logo as the original. Pretty cool. Worth the extra 20 bucks? Meh..
07-29-2015, 12:46 AM | #215 | |
Just the tip
Nevermind I see you put it in the first post.
The Following User Says Thank You to stockysnail For This Useful Post: | Ultramaroon (07-29-2015) |
07-29-2015, 12:46 AM | #216 |
Drives: innovate sc frs
Erm... hope that less motivated partner wasn't me.
Corn fed, Intercooled Innovate sc tuned by vit viper, perrin crank pulley, raceng 72.5 mm pulley, Tomei EL header, Perrin front/mid pipe and 2.5 resonated exhaust, Cusco oil cooler, dual radium catch cans and more!
07-29-2015, 12:55 AM | #217 |
義理チョコ
Absolutely not!
You're already in the keeping-me-honest zone.
08-15-2015, 05:52 PM | #218 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
The Following User Says Thank You to Jmonty For This Useful Post: | Ultramaroon (08-15-2015) |
09-01-2015, 02:36 AM | #219 |
Just the tip
Did this tonight with @Ultramaroon and the clutch is better than ever now and I've done everything else but this is probably the best thing yet.
09-10-2015, 02:16 AM | #220 |
Drives: (SOLD) '13 BRZ Ltd SSM / '91 Miata
Well after being annoyed enough with the clutch to very seriously consider trading this car for something else, or money, I decided to try this slave cylinder swap. I was very hesitant to do this because I thought half the problem was because of the short clutch throw, and making it even shorter seemed like a horrible idea. But at $35 for the parts and fluid, I figured I might as well try it.
I went with the "wrong" slave cylinder that's pictured in the OP (was cheaper, only one anyone had in stock, and I was trying to impulse buy, dammit), except I rotated the clutch line to have it routed more like it was stock instead of the harder bend in the OP. It's crazy how easy it is to swap out, kind of like the oil filter in this thing compared to any other car. Still need to drive more, but so far, it's a definite improvement. I already tried moving the grab point a long time ago, but that didn't really help much. Then in the last few months I pulled the clutch assist spring. That was a major improvement, but still not really right. I know it has already been said, but I think this slave cylinder is the final piece to the puzzle for this weirdo clutch. The pedal actually seems predictable and linear now, albeit with a shorter slip/grab range. But I'd rather it be linear and short than long and goofy or whatever. I haven't been able to shift this smoothly so consistently in this car. Hopefully it continues to be this way and it's not just a honeymoon stage! |
The Following User Says Thank You to rburrow87 For This Useful Post: | jcw99 (10-30-2015) |
09-10-2015, 03:29 PM | #221 |
Drives: 14 Ultramarine FR-S
@Ultramaroon @ck-GT86
How exactly does the clutch line swap improve pedal feel? I haven't really looked at the stock line, wondering if its worth doing. Just looks cleaner and lighter, wondering if the inner diameter is the same as the stock line.
2014 Ultramarine Scion FR-S 2000 Integra LS - SOLD |
09-11-2015, 01:09 AM | #222 | |
義理チョコ
So funny. I bought the wrong one on a whim too, hence the jacked up photos. It's fine. I'll change it after it wears out in 10 years. Don't worry. You aren't imagining it.
09-11-2015, 01:30 AM | #223 | |
Yep, still enjoying it after driving a bunch more today! No problems with feathering, or hill starts, even with the grab point higher than it should probably be. It's much easier to drive and it's hard to understand exactly why. It just seems more linear and predictable now, as if this is the slave cylinder size everything was designed around. It seems strange that a larger slave, which you'd think would simply increase the pedal travel required, could throw it off so much. Must be some odd geometry somewhere. You could sort-of get used to the original one to an extent, but one drive in a different car (NA Miata in my case), and it was just painful going back. This has pretty much saved the car. Now I can concentrate on important stuff like an OFT and E85 or something |
09-11-2015, 01:33 AM | #224 | |
Drives: '13 Raven FR-S, MT
.ck |
Tags |
clutch line, slave cylinder |
Similar Threads | ||||
Clutch Engagement Improved! | enjoyminutemaid | Engine, Exhaust, Transmission | 53 | 11-07-2018 06:31 PM |
Can steering feel, tactility, be improved? Without sacrificing adjustability? | Trettiosjuan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 101 | 08-16-2016 08:14 PM |
Aftermarket Clutch Master and Slave? | Yruyur | Engine, Exhaust, Transmission | 5 | 07-27-2013 10:22 AM |
Hate the feel of the clutch | FRSGeek | Engine, Exhaust, Transmission | 18 | 07-10-2013 01:24 PM |
Clutch feel? | Shit Luck | Engine, Exhaust, Transmission | 5 | 04-21-2013 05:32 PM |
