Old 04-26-2016, 03:07 PM   #43
nichiolas
Drives: GT86
Wondering where is the best jacking point to lift uo the engine ti change engine mounts? Thanks
nichiolas is offline   Reply With Quote
Old 04-26-2016, 03:08 PM   #44
Astroboy
Astroboy's Avatar
Drives: None
Oil pan with a wood block
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-27-2016, 04:47 AM   #45
nichiolas
Drives: GT86
Thanks man
Old 05-05-2016, 03:36 AM   #46
nichiolas
Drives: GT86
How do u align the engine mount to holes on subframe? Cheers
Old 05-05-2016, 03:47 AM   #47
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Perrin mounts? Move the jack supporting the engine in the direction you want it to go, you may need to clearance your subframe, I did.
Decay107 is offline   Reply With Quote
Old 05-05-2016, 04:23 AM   #48
nichiolas
Drives: GT86
Yes, Perrin instruction says I can use a prybar to move the engin around but it seems it doesn't budge no matter how hard I tried...I can't move the trolls jack either....- -!
Old 07-07-2016, 09:28 PM   #49
15limited
15limited's Avatar
I reviewed this thread while waiting for the post man to throw a box of Perrin Motor mounts on my door step.
As other stated, I chose to muscle f*#K the oem driver side mount out, instead of removing the header to make clearance. It took maybe 10 minutes of wiggling and manipulating to get it out, maybe I just got lucky? Running Gruppe-S UEL header, which has no cat, so maybe that helped too.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 07-07-2016, 11:07 PM   #50
Hawk77FT
Drives: GTS 86
I replaced mine with the STI ones and love it! But I completely relate with your story! A job that is supposed to take 30-45, and end up spending 3 hours+ under the car, to the point where you're way to tired to get angry anymore.
You know what is worse? The next day muscle soreness...when you get off the bed like "oh I got this" and 5 sec later "who beat me all night?" I am sure I have been in that position at least five times when I said "next time I will pay someone to do it"!
Hawk77FT is offline   Reply With Quote
Old 02-19-2019, 03:54 PM   #51
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
In light of the valve spring recall my engine will be out, recommendations on motor mounts? I thought it'd be a pretty quick change w/ the engine removed.
slizoth is offline   Reply With Quote
Old 02-19-2019, 04:40 PM   #52
amcp1
Drives: frs
Cusco if you dont care about NVH, STI if you do.
amcp1 is offline   Reply With Quote
Video and short review on the Cusco Engine Mounts and Rear Diff Brace RallySport Direct Engine, Exhaust, Transmission 24 07-23-2018 03:43 AM
Engine Mounts? mrk1 Engine, Exhaust, Transmission 17 05-15-2016 04:31 PM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 04:21 PM
Scion FR-S (2013 2.0L) - Cusco Strengthened Engine Mounts ptuning Engine, Exhaust, Bolt-Ons 0 02-04-2013 10:24 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 01:03 AM
