DIY (Do-It-Yourself) Guides For all DIYs. |
10-22-2019, 04:51 PM | #57 |
JDM Vaping Stance Nation
Drives: 2013 White
I tend to not use OEM spec as much just because they installed it brand new without any wear and tear, dirt or grime. Typically 5-9 ft/lbs below spec.
Clueless
10-23-2019, 04:59 PM | #58 |
Drives: 2013 FRS
Great info, thanks guys! I just ordered a steel one and probably use the grease gun hose trick to relocate the sensor since it's a tight fight around the throttle wires.
Similar Threads | ||||
Oil Pressure and Temp Gauge Install | BokChoiTV | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 12-29-2015 06:19 PM |
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review | Tye300 | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 05-22-2015 12:48 PM |
DIY request: Gauge install and wire routing | mikepaul21 | DIY (Do-It-Yourself) Guides | 3 | 07-05-2014 12:43 PM |
Plot your oil pressure vs temperature | Gords_zenith | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 04-22-2014 06:09 PM |
Temperature Gauge a dummy gauge? | bambbrose | BRZ First-Gen (2012+) -- General Topics | 40 | 08-19-2012 04:29 PM |
