CANADA Canada
Old 09-18-2016, 11:16 PM   #29
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Maybe but there is a lot more to it then just running a wider tire, like suspension setup and what not. If you are on stock suspension run a narrower tire, save some money and track more. The fastest time at Fabi I have recorded with my DL was in another persons car (green BRZ, I think his name was Derrick?) he was about a second faster then my car but with wider tires and coil overs. I don't have enough data to compare between wider and narrower tires to know for sure.
TRAKRAVN is offline   Reply With Quote
The Following User Says Thank You to TRAKRAVN For This Useful Post:
infinity21 (09-19-2016)
Old 09-19-2016, 09:48 AM   #30
wparsons
wparsons's Avatar
Originally Posted by infinity21 View Post
Imo, our local tracks like DDT, TMP, Shanny, etc. are slow so it's better to run wider tires even with our measly 200 hp. I don't know what the optimal width is for the fastest potential lap time but it's probably somewhere between 235 and 255.
DDT definitely benefits from a wider tire, but the other two (SMP full or pro) might be faster with a 225 compared to a 245. SMP is also brutally tough on tires, the extra width may or may not help with wear.
You'd really need to be logging back to back sessions on different tires to get the full picture.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
infinity21 (09-19-2016), Lynxis (09-19-2016)
Old 09-19-2016, 12:13 PM   #31
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Shannonville is definitely tough on tires, primarily because there is no camber built into the track and also that the asphalt is really rough. Besides that, I also think that it is a factor of how much track time you actually get there. I've been to full lapping days where you get half an hour for every hour you're there or lapping evenings and half-days are often completely open lapping. That is more time on track than I've gotten at other full lapping day events where you usually get 20 minutes on track for every hour that you're there. It's certainly the most seat time you can get for your money anyway.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
wparsons (09-19-2016)
Old 09-19-2016, 12:52 PM   #32
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
Yup. My comment was assuming that the suspension is set up appropriately.
DDT is a no brainer for wider tires for sure. TMP, I feel like besides the first two straights, there's no other place to accelerate enough for skinnier tires. Shanny may benefit more from skinnier tires with the extended straights.
At the end of the day, I don't have budget to do a proper test and so I'm only speculating. With my money, I erred on the side of going too wide since it lets me stay out on track longer and will wear better.
infinity21 is offline   Reply With Quote
The Following 2 Users Say Thank You to infinity21 For This Useful Post:
Lynxis (09-19-2016), wparsons (09-19-2016)
Old 09-19-2016, 04:16 PM   #33
wparsons
wparsons's Avatar
That's a good point too. 225's might be faster on some tracks, but you'd be more likely to overheat them much faster. You might get two faster laps, then a bunch that are MUCH slower.
flickr
Old 09-24-2016, 09:30 AM   #34
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
once you get into the track dedicated tire realm of lets say under 200tw, do different tires resist over heating noticeably better than others? Next year I plan on dropping down to a 235 or 245 tire but I'm focusing the mods on my car toward longer sessions so I'm worried now that reducing width may cause my sessions to be limited by tires. I'm not set on any tire yet but what tires have the best resistance to overheating in the re71r, R888, NT01 range?
Canehda is offline   Reply With Quote
Old 09-24-2016, 08:54 PM   #35
Lynxis
Lynxis's Avatar
I don't have much personal experience but the RE71r won't tolerate heat like the R888 or NT01. The NT01 are known to be a great tire in terms of heat tolerance and ultimate dry grip although I hear they are scary in the wet.
wparsons (09-24-2016)
Old 09-24-2016, 09:24 PM   #36
wparsons
wparsons's Avatar
Forget the R888's exist, they tend to heat cycle out quick and lose a ton of grip after.
NT01's will definitely take a ton more heat than RE71R's.
I would give the Maxxis VR-1 a try, the closest to ideal size for us is a 255/40/17, I've heard they take 20-30 minute sessions easily, even in Atlanta heat in the middle of the summer.
flickr
The Following 4 Users Say Thank You to wparsons For This Useful Post:
Canehda (09-25-2016), icybrzzz (10-17-2016), Lynxis (09-24-2016), TRAKRAVN (09-25-2016)
Old 11-02-2016, 03:11 PM   #37
AlphaMotorsports.ca
Drives: Rocket Bunny BRZ, Track FRS
We got 1:21.86 on our FRS on 245 RE71R. Still NA bolt ons + suspension + brakes. Our ultimate goal here is to get into 1:20s NA which we do not feel is out of reach
On one of our BRZs we got 1:23.75 on 225 RE71R which is stock apart from coilovers + Endless MX72 on stock calipers. From the data we collect, should be able to get into the low-mid 1:23s as is.
AlphaMotorsports.ca is offline   Reply With Quote
Old 11-02-2016, 05:34 PM   #38
icybrzzz
Drives: 2015 Scion frz
Would love to go for a ride along with one of the faster guys. Second time at the track and I only managed a 1:33, way slow compared to you guys haha.
icybrzzz is offline   Reply With Quote
Old 11-03-2016, 10:42 AM   #39
wparsons
wparsons's Avatar
Won't be at TMP, but come out to an SPDA/ATTS day at the DDT next summer and you can get some coaching as well as as many ride alongs as you can handle!
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Trac Toy (05-07-2017)
Old 11-03-2016, 04:29 PM   #40
icybrzzz
Yeah I might have to! Would be a good experience for sure
The Following User Says Thank You to icybrzzz For This Useful Post:
wparsons (11-03-2016)
Old 02-10-2017, 12:48 PM   #41
Scracho
Drives: 2018 Subaru BRZ
2014 FRS
Stock Drivetrain
Tein Control Master Flex
17x9 +35 RPF-1
245/45R17 Bridgestone RE71-R
1:26.4 First time at TMP
About 8* Early November day
Its a shame because I only live 35mins away. This year I plan to have far more seat time there.
My first time at Shannonville Full I managed to squeak out a 2:11.6
Scracho is offline   Reply With Quote
The Following User Says Thank You to Scracho For This Useful Post:
icybrzzz (02-10-2017)
Old 05-02-2017, 10:38 AM   #42
86Tony
Drives: 2015 AOZORA EDITION
Did a 1:20.7 on TMP last WED pretty good for first shakedown of the season, hoping to get under 20 next time out
86Tony is offline   Reply With Quote
Fastest Track Times Thread EAGLE5 Tracking / Autocross / HPDE / Drifting 406 11-07-2023 10:40 AM
NZ Track times diss7 NEW ZEALAND 2 03-03-2014 12:42 AM
FI Track Times wrxgoose Forced Induction 0 07-24-2013 02:17 PM
Can too much grip hurt track times? ayau Tracking / Autocross / HPDE / Drifting 53 04-22-2013 10:28 AM
Top Gear (UK) track times GeeTee86 AFRICA 29 02-15-2013 07:04 AM
