Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Tracking / Autocross / HPDE / Drifting
Old 03-30-2018, 08:14 PM   #127
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
Wow just found this thread. This is super dope
Drambeenie is offline   Reply With Quote
The Following User Says Thank You to Drambeenie For This Useful Post:
VerusEric (04-20-2018)
Old 04-20-2018, 10:26 PM   #128
VerusEric
Design Guy
VerusEric's Avatar
Drives: 2014 BRZ, 1993 MR2 Turbo
I apologize for the delay in updates; we just keep stacking on more projects and forum posts seem to take a back seat.
Production update: We are waiting on the billet uprights right now. After we get these, we can send everything off for coating and we'll have our first production run ready. We're hoping sometime in May now. It is definitely taking a bit longer than we had hoped and we are sorry about that. A lot of time and effort has been put into this kit, we've learned a lot and we're very excited about offering the wing!
Validation Update: So we have a few ways we are going to be validating the rear wing's performance.
1) Strain Gauges: Strain gauges allow us to measure the forces an object sees. To simplify it, as the object deforms (microscopically, not visually), the gauge's resistance will change as well. By measuring this change in resistance, we can accurately estimate the stress the component sees. From here we can calculate the forces the upright is seeing from the wing and correlate this to our CFD data. We are going to attempt to correlate both drag and downforce; but because drag is so small, this will likely only allow us to correlate downforce generated in the real world to downforce generated in CFD.
2) Coast Down Tests: We plan on doing some coast down tests to validate drag force changes. We have a good plan together, we just need to implement this and will in the next few weeks.
I have also driven the car home for a few weeks while we were getting the uprights ready for testing. I personally drive the same stretch of highway every day to and from work, approximately 20 miles at 70MPH. I have driven this with and without the wing installed, and the average mileage has been extremely comparable between the two. This is a good initial sign that our drag estimates for the wing are accurate in CFD, and the coast down tests we will be doing shortly will hopefully prove this as well.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 11 Users Say Thank You to VerusEric For This Useful Post:
arthur93 (04-24-2018), Code Monkey (04-20-2018), Cybmx (04-21-2018), DAEMANO (04-24-2018), DustinS (04-23-2018), Hyper4mance2k (05-11-2018), makinen (04-23-2018), Racecomp Engineering (04-24-2018), RallySTI (05-02-2018), Spuds (05-31-2018), will300 (04-21-2018)
Old 04-24-2018, 04:11 AM   #129
arthur93
Drives: Toyota 86 GTS
Will you be doing an initial group buy for this? If so when would this likely occur? Pricing?
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
Old 05-01-2018, 05:34 AM   #130
Tiz
Drives: Subaru BRZ
Do you have to remove the OEM wing ( https://cdn.shopify.com/s/files/1/02...g?v=1400503439 ) or can you reasonably combine the Verus wing with the OEM wing (sort of double wing)? Thanks.
Tiz is offline   Reply With Quote
Old 05-16-2018, 01:29 PM   #131
VerusEric
Design Guy
VerusEric's Avatar
No, we are basically just trying to release it as soon as it is ready. Pricing is somewhere around 1650 I think.
No, you can use the OEM wing (if you want to call it that) and we actually tested it with the Perrin Gurney Flap in CFD .
I'm sorry again for how long this has taken but we have had a lot of projects going on all at once and like all big projects, this one has taken longer than we anticipated.
The billet uprights are in and after QC they went straight to anodizing. We're pretty happy with how they turned out! Yes, that is a large radius'd leading edge and a knife-edged trailing edge; because aero-nerds. Believe it or not, this does improve efficiency and we ended up purchasing custom tooling for our machinist to be able to do this .
Thanks,
Eric
The Following 10 Users Say Thank You to VerusEric For This Useful Post:
arthur93 (05-16-2018), DAEMANO (06-07-2018), Devil 86 (05-16-2018), DustinS (05-16-2018), Hyper4mance2k (05-25-2018), Racecomp Engineering (05-16-2018), Spuds (05-31-2018), StegaDragon (05-16-2018), Takumi788 (05-16-2018), TRAKRAVN (05-16-2018)
Old 05-18-2018, 11:35 AM   #132
Jonsey
Jonsey's Avatar
Do the routed out pockets cause turbulence, and if so, how does that affect what you are trying to achieve with the radiused leading edge and the knife-edge trailing edge?
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 05-18-2018, 04:53 PM   #133
plucas
Aero Guy
plucas's Avatar
Drives: Subaru
Very very little. The pockets fill with a deadwater region, similar to the front bottom of a windshield, and the rest of the flow stays attached to the uprights. The radiused front and knife-edge trailing edge still function perfectly even with the pockets. The deadwater region does cause a loss in efficiency due to the slight increase in drag. It was a tradeoff for the weight savings.
plucas is offline   Reply With Quote
The Following User Says Thank You to plucas For This Useful Post:
Jonsey (05-19-2018)
Old 05-18-2018, 08:13 PM   #134
cjd
cjd's Avatar
Drives: 2017 BRZ
CF inlays? Because this needs to cost more...
Old 05-21-2018, 07:24 AM   #135
plucas
Aero Guy
plucas's Avatar
Drives: Subaru
If we did carbon, it would be a full carbon upright. Sadly, this market wouldn't pay for the increase this would cause. Two carbon uprights with tooling would add a significant amount to our cost.
cjd (05-21-2018)
Old 05-30-2018, 08:08 PM   #136
VerusEric
Design Guy
VerusEric's Avatar
We are getting very close to being able to issue these for sale, which is exciting! A few small pieces of the puzzle and packaging and they'll be done. We'll be releasing full information packets at that time as well, and will link that data here for viewing. This will include coast down testing and strain-gauge measurements.
We've done quite a bit of testing as far as what the trunk and wing can handle. This is a picture of Paul and I standing on the wing for the first time (~300lbs). The trunk took it well and the wing/uprights did great. This was before we received some other pieces of the wing kit which further strengthens the trunk as well, so we are happy with the results!
Thanks,
Eric
The Following 8 Users Say Thank You to VerusEric For This Useful Post:
Code Monkey (05-31-2018), DAEMANO (06-07-2018), finch1750 (06-07-2018), Hyper4mance2k (06-13-2018), JoeC (05-30-2018), Kestrel (05-30-2018), Pat (05-30-2018), tehShirt (05-30-2018), TheStig85 (05-30-2018)
Old 05-30-2018, 11:59 PM   #137
johan
Drives: '14 981CS, '99 NB1
Thanks,
Eric
johan is offline   Reply With Quote
The Following 4 Users Say Thank You to johan For This Useful Post:
Hyper4mance2k (06-13-2018), jbailey8748 (06-05-2018), Tristor (06-06-2018), VerusEric (06-06-2018)
Old 06-06-2018, 07:51 PM   #138
VerusEric
Design Guy
VerusEric's Avatar
We got the first upright back from anodizing and I was able to throw a full set on the spare blue trunk we had. Our latest addition to team Verus luckily has a blue BRZ as well, so over the weekend we put this assembled unit on his car. We were finally able to see what the wing looks like with all of the parts coated. Below are the very first pictures of the wing; as we will sell it.
We realize it is not for everyone, but we are quite happy with the package! We'll be installing a set on Clay's WRB BRZ with a ducktail shortly (which will be used for the install manual). We'll share those photos too.
Thanks,
Eric
The Following 9 Users Say Thank You to VerusEric For This Useful Post:
cjd (06-06-2018), Code Monkey (06-06-2018), DAEMANO (06-07-2018), Hot-Lava_Dave (06-14-2018), Hyper4mance2k (06-13-2018), johan (06-07-2018), Lonewolf (06-06-2018), TheStig85 (06-06-2018), Tristor (06-06-2018)
Old 06-06-2018, 08:54 PM   #139
cjd
cjd's Avatar
Drives: 2017 BRZ
...the very first pictures of the wing; as we will sell it.
I did not realize it came with an entire car!
Not in my future because rules and stuff, but it's been a treat to read through all the notes you've shared along the way. Thanks for doing that! Hopefully this sells like, uh, beer. (Hotcakes don't seem as likely a seller with the weather we're likely heading into).
The Following User Says Thank You to cjd For This Useful Post:
VerusEric (06-10-2018)
Old 06-06-2018, 11:28 PM   #140
Pat
Pat's Avatar
Drives: 2014 BRZ
I love everything about it. Nice work, gents.
The Following User Says Thank You to Pat For This Useful Post:
Search this Thread:
Advanced Search
WTB: Header, Rear Diffuser, Rear Wing/Spolier, Trunk, Tail lights Apples_ZN6 Canada Classifieds 0 06-04-2017 11:27 AM
Street Faction Engineering Chassis Mount Wing FRS/BRZ hellokyles Exterior Parts (Aero, Lighting, Etc.) 19 08-19-2016 05:20 AM
Freed Engineering custom metal fabrication and parts development bFreed Announcements, Contests, Giveaways 23 03-24-2012 03:35 AM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 07:11 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
