Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ > BRZ First-Gen (2012+) -- General Topics
BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe
Old 09-14-2019, 02:24 PM   #15
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by _keepkushin_ View Post
you would more than like have to run a sandwhich adapter to get a reading as i am currently using torque pro and it does not have a eot sensor widget i would suggest looking into a mount and a custom gauge to your liking.
Torque Pro does have a gauge for engine oil temperature. I know this because I use it and have the gauge set up on my screen. You don't need a sandwich adapter to get a reading that is already there.
Old 09-14-2019, 05:19 PM   #16
gravitylover
What about oil pressure? I assume there's already a sensor for that.
Old 09-14-2019, 06:23 PM   #17
extrashaky
There is not. You have to use an aftermarket sensor and gauge for oil pressure. Apparently the designers didn't think oil pressure was important in this car.
There is, however, a port already tapped for an oil pressure transducer right on top of the block so that you don't have to use a sandwich plate.
The Following User Says Thank You to extrashaky For This Useful Post:
gravitylover (09-15-2019)
Eng coolant temp sensor location D K Engine, Exhaust, Transmission 28 08-27-2014 05:30 PM
Addition of a radiator hose sensor temp adapter & coolant bleeding FutureFT86 Engine, Exhaust, Transmission 9 07-21-2014 11:50 PM
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 01:22 PM
OEM Oil Temp Sensor Location Khorne Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 01-15-2014 10:38 PM
Dealer installed alarm shock sensor 1stGenBRZ86 BRZ First-Gen (2012+) -- General Topics 2 07-19-2013 10:20 AM
