86SPEED
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes
Suspension | Chassis | Brakes Relating to suspension, chassis, and brakes.
Old 11-24-2017, 03:46 AM   #29
churchx
churchx's Avatar
Drives: 2014 orange GT86
nico rsx: this or something similar self-assembled, no?
Old 11-24-2017, 02:18 PM   #30
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Yes, I think something like this would be required, but when people talk about lowering their BRZ and changing the LCA, I've never heard them talk about changing that part. Only that the LCA need to have the mount for the sensor. Maybe the rod is already adjustable on our car. I haven't look.
nico_rsx is offline   Reply With Quote
Old 11-24-2017, 02:41 PM   #31
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by 007BRZ View Post
Well, I guess I was too technical in what I wrote. I will take that bet! If the rear camber arms you buy DO NOT have a bracket for the headlight sensor, You all have a problem in Houston. That's why my comment on the Verus arms ( See pictures)
No, you were not too technical in what you wrote.
What you wrote (Performance Package, "Brembos") had nothing to do with the auto headlight issue.
Perhaps next time word your post properly, something like "The 2017 Performance Package requires specific arms for use with the auto headlight level adjuster."
Cole (11-25-2017)
Old 11-24-2017, 02:43 PM   #32
mav1178
mav1178's Avatar
Most other systems for auto level headlights reset the sensor when you start the car.
This way, the headlight can compensate for a loaded trunk vs an empty trunk.
The only issue I can think of is if the car is lowered past the adjustment range of the sensor or the movement of the rod. Then you might run out of room for the rod to provide sensor feedback.
Old 11-24-2017, 03:17 PM   #33
He who smelt it...
Drives: 14 FRS Hot Lava
More like this: http://www.ft86club.com/forums/showthread.php?t=123568
Tcoat is online now   Reply With Quote
mav1178 (11-26-2017)
Old 11-25-2017, 12:07 AM   #34
nico_rsx
What I'm thinking is that lowering the car has the same effect as loading the trunk, because it probably change the angle on the LCA, so the headlight would compensate by pointing down because it's thinking the rear is more compressed than the front, but since your lowering also the front, the headlight end up pointing down.
This is all based on the assumption that lowering the car change the angle of the LCA. If not, what's the difference on the LCA between lowering the car and putting weight in the trunking?
The Following User Says Thank You to nico_rsx For This Useful Post:
wparsons (11-30-2017)
Old 11-30-2017, 08:53 PM   #35
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
While we are on the subject, how can the level sensor continue to work with coil-overs? I mean even with aftermarket LCA, if you change the height of the car doesn't it change the angle of the LCA? If yes, then do you have a way to adjust the angle of the sensor according to the height you adjust the coilovers?
You can use the adjustment on the back of the headlight on a flat surface to adjust them back to center. There is an 8mm bolt you turn to manually adjust.
I had to do the same thing when I lowered my 17BRZ and got aftermarket LCA. worked like a charm, took 15 minutes, no need for additional parts.
mjanmohammad is offline   Reply With Quote
The Following 2 Users Say Thank You to mjanmohammad For This Useful Post:
nico_rsx (12-02-2017), wparsons (11-30-2017)
Old 12-02-2017, 04:02 PM   #36
nico_rsx
I hadn't thought about that, really interesting answer. I didn't know there was still a manual adjustement on the headlight. I'm guessing you have the automatic sensor adjustment on your BRZ?
What LCA did you use?
Thanks a lot
Old 12-02-2017, 04:26 PM   #37
mjanmohammad
Thanks a lot
I'm using the Megan Racing LCA, they had a spot on them to attach the leveling sensor but they were pointed all wrong after the install. Adjusting the knob on the back of the headlights worked like a charm.
nico_rsx (12-02-2017), wparsons (12-04-2017)
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 208 10-08-2018 02:29 PM
2017 BRZ Performance Package C&D Lightning Lap lynk26 FR-S / BRZ vs.... 27 10-04-2017 05:49 PM
1slowbrz's 2017 wrb performance package 1slowbrz Member's Car Journals 3 05-20-2017 05:03 PM
WTB: OEM 2017 Performance package wheels mjanmohammad Want-To-Buy Requests 1 03-03-2017 03:35 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
