Old 02-22-2015, 02:28 PM   #1177
Captain Insano
Same question. I have tc105n +35 17x9 and currently running 245s. Eibach prokit springs front camber bolts and rear LCAs. Dreaming of 265 or 275 when these tires are dead. At least 255s.
Captain Insano is offline   Reply With Quote
The Following User Says Thank You to Captain Insano For This Useful Post:
#maverick# (02-22-2015)
Old 02-22-2015, 03:33 PM   #1178
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by #maverick# View Post
Is anyone running a 265 or 275 tire on a 17x9 wheel?
honestly a 255 would probably be best. its more than enough tire.
265 would also fit but depending on tire brand, but it would bulge probably.
contact patch doesn't only have to do with a bigger width tread btw...so don't get caught up in tire sizes, anything 255+ is pretty significant IMO.
you're on stock struts in the front...dont really know how much clearance you will have with a 255, or a 265....in the rear you will be fine, but idk about the front.
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
#maverick# (02-24-2015)
Old 02-22-2015, 04:19 PM   #1179
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
i think im going to go with 265 toyo r888s in back and 255 in front. I know mustang guys run 275/40 on 17x9s
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 02-26-2015, 09:55 AM   #1180
Brzerker
Brzerker's Avatar
Drives: World Rally Blue BRZ
Originally Posted by adprokid View Post
On 255 you won't rub and you won't need to roll
Hi,
I am currently on 255/35 18 rear but I'm still rubbing during hard cornering. I read in the earlier threads that it's rubbing on some plastic inside the fender. Is there anything I can do to remedy this? Should I add more camber? Currently on 2 deg rear.
Extra information just in case, swift springs on koni yellows, goodyear eagle F1 asym, cusco LCA, TE37SL 18X8.5 45 wheel
Brzerker is offline   Reply With Quote
Old 02-26-2015, 11:12 AM   #1181
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Originally Posted by Brzerker View Post
Hi,
I think you have same issue as this guy, simple fix.
http://www.ft86club.com/forums/showthread.php?t=44177
adprokid is offline   Reply With Quote
Old 02-26-2015, 11:37 AM   #1182
Imrac
Drives: 13 SWP BRZ Prem
Be careful, the stock spring perch is pretty dang close.
Here is a photo with 245/40 tires when I was running RCE Yellows with 17x9 +35
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following User Says Thank You to Imrac For This Useful Post:
Captain Insano (02-28-2015)
Old 02-26-2015, 11:45 AM   #1183
pleong
Drives: 2013 Whiteout FR-S
Originally Posted by texasbound972 View Post
Here is my 275/35/18 squared setup. Need LCA's so the rear can stop scraping!
You might need more than rear LCAs to get it to stop rubbing.
Do you know where you're rubbing? I'm going to assume you're rubbing on the rear bumper tabs.. If that's the case, the width of the tire isn't your only problem, it's the ratio as well. At 35% that's a tall tire. I had 265/35 and they would constantly rub that bumper tab.. I'm not very low either, and I was at the stiffest setting when I ran those. It's going to be a big pull to fit those to where it won't rub.. I've tried lol
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
The Following User Says Thank You to pleong For This Useful Post:
Jive Turkey (02-26-2015)
Old 02-27-2015, 10:45 PM   #1184
VroomVroom86
VroomVroom86's Avatar
Drives: 2013 Firestorm FRS MT
Here's a terrible iphone photo of my set-up. I'll get some better photos eventually, but I was too excited.
Weddssport Sa-10r 18 x 9.5 +45
265/35/18 Sumitomo HTR Z III
VroomVroom86 is offline   Reply With Quote
Old 02-27-2015, 11:05 PM   #1185
swarb
^looks great!! some tint and red tails would good too! more pics with the aero fin!
The Following User Says Thank You to swarb For This Useful Post:
VroomVroom86 (02-27-2015)
Old 02-28-2015, 04:10 PM   #1186
VroomVroom86
The Following User Says Thank You to VroomVroom86 For This Useful Post:
Porcupint (02-28-2015)
Old 03-03-2015, 02:54 AM   #1187
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
WedsSport 18x9.5 +45 with 255 tyre
Might try with 265 on next change.
More pics here
http://www.ft86club.com/forums/showthread.php?t=83798
nzer is offline   Reply With Quote
The Following 3 Users Say Thank You to nzer For This Useful Post:
Manji (03-20-2015), umpadupa (03-04-2015), VroomVroom86 (03-04-2015)
Old 03-06-2015, 02:15 PM   #1188
nzer
nzer's Avatar
I've got the same wheels but with 255/35/18 tyres.
They just rub at absolute full lock.
I was thinking of going 265/35/18 at next tyre change. Do yours rub at full lock?
Old 03-06-2015, 02:17 PM   #1189
nzer
nzer's Avatar
Your pics seem to have disappeared. Are you able to load again?
I have the same wheels but with 255/35/18 tyre and the just rub at full lock.
Do your 265 tyres rub at full lock?
Old 03-07-2015, 01:30 PM   #1190
VroomVroom86
It does rub a lot at full lock, but I am rarely fully locking my wheels. I don't mind because the grip is spectacular and the meaty set-up looks great.
nzer (03-07-2015)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
