Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
10-04-2016, 03:34 AM | #15 |
Drives: 2016 Cosworth 2.2 BRZ
If your A/C or defroster is on when you start your car, it will shake worse. Your car is in open loop mode when it is cold, meaning it is receiving no feedback from some of the sensors. It goes by a pre-programmed map to determine engine parameters. It doesn't always get it right. When you run the A/C or defroster you drain power off the engine and it has trouble compensating. If this is the case, turn off your A/C and see if the engine runs smoother.
It's a small displacement 4 cylinder. Shaking is going to be normal. |
The Following User Says Thank You to sly For This Useful Post: | jcw99 (10-04-2016) |
10-15-2016, 05:13 PM | #16 |
Drives: auto 2016 frs
unfortunately it still shakes, usually shakes when im making a turn, left or right. everytime im on a stop, turning it shakes. anyways i made an app. with toyota i will be leaving the car there. thanks everyone!
10-16-2016, 12:10 AM | #17 |
Does it start normally or does the engine turn over slowly? Do the lights dim when you hit the brakes? Could be a weak battery or faulty charging system. This car has an electric power steering system and when you turn the wheel, it will draw power off the battery. If the battery is weak, the car will shake.
Another possibility is you have a problem in the transmission or the torque converter. If the torque converter is not stalling out properly when you are sitting still, it will drag on the transmission and bog down the engine. In other words, your transmission may not be disengaging when it should and is taking power from the engine. Let us know what Toyota says. |
10-16-2016, 12:22 AM | #18 |
Drives: 2015 CWP BRZ Limited
This has to be shitposting right?
The Following User Says Thank You to jawn For This Useful Post: | Ultramaroon (10-16-2016) |
10-16-2016, 12:26 AM | #19 | |
義理チョコ
It's the Torsen diff. Normal.
The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
10-16-2016, 01:52 PM | #20 |
Drives: 15 FR-S Firestorm MT
Ultramaroom is right. It's more like a light buzz/ vibration coming from the rear rather than saying your whole car shakes. You're kind of blowing things out of proportion.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
The Following 2 Users Say Thank You to Joyride86 For This Useful Post: | Kana (10-23-2016), Ultramaroon (10-16-2016) |
10-16-2016, 03:23 PM | #21 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Yeah. Sounds like normal "cold LSD" symptoms, and perfectly normal. I agree with Ultramaroon. It's normal for this differential to bind a little bit before it warms up.
The Following User Says Thank You to Stang70Fastback For This Useful Post: | Kana (10-23-2016) |
Similar Threads | ||||
Rear end shaking under acceleration | enjoyminutemaid | Issues | Warranty | Recalls / TSB | 23 | 06-18-2016 05:15 PM |
Shifter Shaking | moe_5 | Issues | Warranty | Recalls / TSB | 5 | 12-07-2013 12:46 PM |
shaking of car | Adam86 | AFRICA | 3 | 05-17-2013 08:42 AM |
Severe Shaking while in Idle from 0-5 mph | ScionFR-S | Engine, Exhaust, Transmission | 1 | 10-15-2012 09:42 PM |
CEL Blinking/Hard Shaking. | _F-R-S_ | Issues | Warranty | Recalls / TSB | 4 | 09-16-2012 07:43 PM |
