Old 08-28-2018, 08:58 PM   #715
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Robbierayy1 View Post
Thanks man! Would the 10w-30 oil be better for my car than a 5w-30 under higher loads? I sometimes accelerate aggressively and sometimes go wide open throttle!
It doesn't effect load in that manner beat on it all you want.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Robbierayy1 (08-28-2018)
Old 02-08-2019, 03:01 PM   #716
Jesxse
Drives: 2015 BRZ
Does anyone know what yellow gas cap fits the BRZ? I’d like a replacement for when I run E85
Jesxse is offline   Reply With Quote
The Following User Says Thank You to Jesxse For This Useful Post:
ermax (02-08-2019)
Old 04-20-2019, 01:52 PM   #717
Victorscp
Drives: 2018 BRZ premium
how do you monitor fuel trims if you are using the tactrix cable?
Victorscp is offline   Reply With Quote
Old 04-20-2019, 02:28 PM   #718
ermax
ermax's Avatar
You could log over USB to a laptop in real time. Or get a $10 BT OBD2 adapter to watch the trims. You really only need to watch the trims when first switching to E85 though. After that you just fill up and go.
The Following User Says Thank You to ermax For This Useful Post:
Victorscp (04-20-2019)
Old 04-25-2019, 12:31 AM   #719
palanza87
Drives: 06 Ford Mustang
Hello, so I bought a used 13 FRS about two years ago and just now realized it came with this openflash reader. So I got the software manager installed and its connected to my computer, loading all of the info. I guess my main question is, how would I find out what tune is installed on the car? I think I can figure out how to get the e-85 tune going for the mods installed but I'd like to make sure I know which is which.
palanza87 is offline   Reply With Quote
Old 04-25-2019, 02:55 AM   #720
steve99
Assuming the tablet is married to car amd car has not beeen flashed with a different device. Plig tablet into car go to tuning then theor should be an asterix * next to the tune currently in vehicle
Old 06-19-2020, 02:25 AM   #721
Pizzachicken
Drives: Asphalt '16 FRS
If you guys don't mind checking out my data to make sure everything is looking good. I've read through all 50+ pages of comments, and my logs look almost as expected except for a couple concerns. This is on first tank of e85 (filled 11.2 gal) and have driven far past the recommended range before doing my first pulls.
LTFT should be +- 10% throughout, at one point I did have it jump up to 11.72% ~700rpm, not sure what that's about. And my LTFT has never dips under -0.78. I average around 4.5%
WOT AFR should see 12's is what I gathered, but when past 6krpm it goes into 11's, 11.25 was at redline.
This is off the stock OFT tune, as I wouldn't know how to adjust values and prefer not to touch that. Do these conditions look good to proceed and enjoy? Thanks
https://datazap.me/u/pizzachicken/61...data=1-9-11-13
https://datazap.me/u/pizzachicken/61...=1-2-4-9-11-13
Pizzachicken is offline   Reply With Quote
Old 06-19-2020, 03:23 AM   #722
tomm.brz
Drives: brz 2017 hksv2
it would benefit a little maf scaling, but doesn t look so bad, you can drive like that no worries, looks solid
The Following User Says Thank You to tomm.brz For This Useful Post:
Pizzachicken (06-19-2020)
Old 06-19-2020, 12:38 PM   #723
Pizzachicken
Great. I was just wondering if there's any reason for my numbers to be slightly off from what others have suggested, and if it's normal for LTFT to be +11 even if briefly. Otherwise, what should I do with MAF scaling? By "benefit" would that mean making it safer for the engine?
Old 06-19-2020, 01:55 PM   #724
tomm.brz
it doesnt look off, and it seems safe
maf scaling will bring smoother overall and bit more power apparently since it seems rich in spots during the pull for e85, but not so relevant, you could avoid
if you send me the tune i ll adjust a bit for you
Old 06-19-2020, 02:07 PM   #725
Pizzachicken
Ok attached my file, it's just the one directly from OFT. I appreciate it. It'll be okay to make adjustments off this data given it's still my first tank and the possibility of varying e% in future fill ups?
File Type: zip (E85) Stg-2-Plus-E85-v4.03-LC-FSS-ZA1JF40C.zip (478.1 KB, 87 views)
Old 08-29-2021, 10:39 PM   #726
Collin Long
Collin Long's Avatar
Drives: 2013 Scion FRS
Exclamation In Dash Fuel Economy Meter
What exactly does this change when changing the Fuel Display Offset Multiplier? and why doesn't this come with the tune?
Collin Long is offline   Reply With Quote
Old 08-30-2021, 09:04 PM   #727
Purist
Purist's Avatar
Drives: Subaru BRZ
Hey mate I'm only answering because no one else has. I'm no expert. I think this adjusts the display so it displays fuel usage correctly. E85 gets used at 25% higher rate.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
The Following User Says Thank You to Purist For This Useful Post:
steve99 (08-31-2021)
Old 08-31-2021, 06:08 PM   #728
Collin Long
Thank you! I had guessed that is what it was but wasn't 100%
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
stock BR-Z, much detonation during shifts: tune? elefunkd Engine, Exhaust, Transmission 69 07-26-2013 04:20 PM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
