Software Tuning Discuss all software tuning topics. |
01-31-2018, 08:38 PM | #15 | |
Drives: Crapcan
The stg 2 OTS tune I started with did not have P0420 disabled. I had to do it manually. So again, I was just confused as usual. |
01-31-2018, 09:31 PM | #16 | |
Drives: 2017 BRZ
01-31-2018, 09:37 PM | #17 | |
Drives: 2014 Subaru BRZ Limited 6MT SSM
So if you have a catless header, and you have an OFT OTS tune, you need to edit the tune to disable the P0420 code, and then your car will show emissions readiness? I just want to know how to have all emissions readiness when running a catless header and OFT OTS tune lol. |
01-31-2018, 11:49 PM | #18 |
[EUROBEAT INTENSIFIES]
Drives: 2015 Scion FR-S Steel
To piggyback on what @ApexEight said.
If you just need to pass smog with the least amount of headaches, put your OEM exhaust system back on and flash back to the factory tune. After that whole fiasco is over with at the smog station, put your aftermarket parts back on and go back to OFT Stg 2. EZPZ
02-01-2018, 09:20 AM | #19 |
Drives: 17 Series Yellow BRZ
Sounds like a hassle and having to buy gaskets all the time
The Following User Says Thank You to Jasonb For This Useful Post: | Chimera (02-01-2018) |
02-02-2018, 06:46 AM | #20 | |
Going back to stage 1 or stock will be fine you might throw p0420 code though |
02-02-2018, 07:36 AM | #21 |
Panda Trueno
Drives: No twin now.
Why not get one of those CEL eliminator spacers and flash back to a stock tune. You'll be fine for emissions testing and its only one thing to change vs everyone saying change your whole exhaust.
If you're having an issue with the readiness / code, flashing to stock will fix that issue, but you will probably have the actual CEL at that point. |
02-09-2018, 09:18 AM | #22 |
Drives: White Auto 86
UPDATE:
this might help some of you. i have UEL catless headers, + custom exhaust with no muffler only a resonator, Stage 2 tune does not pass emission checks at all. Flashed it back to OEM, drove around ~75 miles for drive cycle I passed emissions. Tuned back to stage 2, No need to take headers off, might not be the same for everyone, but it worked for me! Thank you to everyone that helped |
02-09-2018, 10:15 AM | #23 | |
02-09-2018, 11:45 AM | #24 | |
Drives: FRS
I think he's got all the sensors, just no cat
02-09-2018, 12:36 PM | #25 |
02-09-2018, 01:15 PM | #26 |
Drives: Crapcan
02-09-2018, 03:47 PM | #27 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Largely because noone i know has ever been able to pass a smog test in California with any sort of cat delete. Even flashing back to stock with a spacer to trick the ECU didnt pass. It definetly doesnt pass visual but some shops honestly dont check.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
02-10-2018, 05:32 PM | #28 | |
Wdym "normal" on autos, I've had my 86 for a long time and never got a transmission code. I've also passed OBD2 smog checks with the stage 2 tune.
Similar Threads | ||||
Best EL catless header? | shu5892001 | Engine, Exhaust, Transmission | 38 | 01-22-2018 10:36 PM |
catted headers + OFT = automatic smog fail? | DarkSideFRS | Southern California | 7 | 12-12-2017 03:24 PM |
catless header vs catless frontpipe | steveholt | Engine, Exhaust, Transmission | 30 | 10-10-2017 07:13 PM |
Best UEL catless header | bozack | Engine, Exhaust, Transmission | 13 | 04-24-2015 02:00 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
