09-07-2016, 03:00 PM | #1611 | |
Drives: 2015 BRZ
We plan on making this car competitive in NASA ST2, which means long sessions in the summer at race pace. Jake |
The Following 4 Users Say Thank You to GSpeed For This Useful Post: |
09-08-2016, 06:13 PM | #1613 |
Drives: 2015 Halo FR-S
I don't get on here much. Sorry to the guys I haven't responded to yet. I will attempt to answer your questions here along with an update to my current situation.
The throttle body position sensor issue was unresolved directly but I did notice some chafing to the harness where I had mounted it. I originally tied it to the cold side of the AC pump line to keep it away from the belts. I moved it away from that and haven't had the issue return and no limp mode. I don't know anything about the Mishimoto upgrade to fit with this kit. Pictures of the heat shield solution I made will be included. Finally, I've run into a P0171 lean issue and discovered a vacuum leak. My bypass valve failed and doesn't actuate properly and allows unmetered air to bypass the MAF throwing off my fuel trims under vacuum condition. We discovered the issue with a smoke test. We put the smoke probe in the TMAP sensor bung and without even blocking the intake we found the leak. We moved the smoke probe to the bypass valve hose and it leaked significantly confirming our discovery. Edelbrock is sending me a new bypass valve under warranty. Picture also included. Last edited by Tomcat07; 09-08-2016 at 06:24 PM. |
09-08-2016, 11:36 PM | #1614 | |
Drives: FRS, Supra, Colorado D, GLC63
Saw your post on FB, glad you found the issue. I'm hoping this bypass issue is just a small bad batch or something.
09-09-2016, 01:50 PM | #1615 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Will be installing this today. Thanks @DeliciousTuning
09-09-2016, 08:04 PM | #1616 |
Simply Forgotus
Got it the D-Box installed...piece of cake. Took it for a spin...nothing crazy, normal driving for a couple miles, made a 20 minute stop, started the car back up and had a check engine light! WTF!
Checked it with Torque and it was a P0451 code (Evaporative Emission Control System Pressure Sensor Range/Performance). Reset it and it hasn't come back...I don't think the D-box has anything to do with that since it just connects to the MAP and MAF. I'll check it out tomorrow to see if maybe I bumped something or knocked something loose during the install. |
09-11-2016, 12:07 AM | #1617 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I received my CARB sticker in the mail today from Edelbrock.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
The Following 6 Users Say Thank You to shiumai For This Useful Post: | BigFatFlip (09-11-2016), Bonburner (09-22-2016), CSG Mike (09-11-2016), Edelbrock LLC (09-16-2016), Irace86 (09-11-2016), Silverfox (09-11-2016) |
09-11-2016, 08:37 PM | #1618 | |
Drives: 2013 Subaru BRZ
-craig
2013 Subaru BRZ - AT - Satin White Pearl - Edelbrock Supercharger
2016 Subaru WRX STi - World Rally Blue Pearl Last edited by caschnd1; 09-11-2016 at 09:22 PM. |
The Following User Says Thank You to caschnd1 For This Useful Post: | BirdTRD (09-11-2016) |
09-11-2016, 09:39 PM | #1619 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
09-11-2016, 09:44 PM | #1620 |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
09-11-2016, 10:05 PM | #1621 |
I was going to ask folks that same question. Right now it's in my folder at home but I'm keeping a copy of the accompanying letter with my registration in the glove box. I believe you just need the EO number and present it during inspection; it doesn't have to be actually on the part.
09-12-2016, 01:04 AM | #1622 | |
Funny enough, I got a little bit of run around initially: called Edelbrock 1-800 number and they told me to call my dealer (the racer's line) then Neal tells me he was told to have me contact Edelbrock directly wtf?
Couple days later, Edelbrock e-mails me directly asking for my mailing address. Got the CARB sticker in a couple of days. Quote:
The Following User Says Thank You to BigFatFlip For This Useful Post: | Silverfox (09-12-2016) |
09-12-2016, 11:58 AM | #1623 |
Mike from Edelbrock replied to my inquiry and said that that's what they generally recommend.
The Following User Says Thank You to shiumai For This Useful Post: | Edelbrock LLC (09-16-2016) |
09-16-2016, 07:40 PM | #1624 |
Drives: 2013 Black BRZ Limited
On my way back home from work and got the same engine light and traction light from a few hundred miles ago. Pulling the DTCs I've got two: P0171 System Too Lean Bank 1 C1201 (no description but part of the ABS module) Under vacuum long term fuel trim is still around +15% |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
