Old 07-26-2012, 10:01 PM   #141
kendalldwhite
kendalldwhite's Avatar
Drives: Mint-Tiffany blue FRS
Same here, on the shelf. waiting on my car. Im not sure if this is the same concept but i had an idle issue with my mustang i just unplugged the throttle positioning censor and it stopped, the rpms always being high. I don't have my car yet to look at the engine components so i can hardly help u at this point. maybe after i bolt on my pulley.
Originally Posted by ruskymx View Post
Yes, it would drop to 300-400 and stumble a little before returning to 650.
I'll remove the pulley if I get a CEL so they can't blame it on that even though I told my service department about it when the stock pulley was on. I got tired of looking at my pulley sitting on a shelf so I installed it on Wednesday.
kendalldwhite is offline   Reply With Quote
Old 07-27-2012, 10:09 AM   #142
KRAZYK
Self Entitled
KRAZYK's Avatar
Drives: 13' Red FR-S, 12' Toyota Tundra
Anyone have a link to purchase one of these?
KRAZYK is offline   Reply With Quote
Old 07-27-2012, 10:34 AM   #143
Opposed
Drives: 2013 Asphalt FR-S
Look in the commercial market place section in the forum twards the botton. Then go into the engine section. There are quite a few vendors selling these.
Opposed is offline   Reply With Quote
The Following User Says Thank You to Opposed For This Useful Post:
KRAZYK (07-27-2012)
Old 07-27-2012, 11:32 AM   #144
KronosPerformance
KronosPerformance's Avatar
Drives: 2009 Subaru STi
Send a message via AIM to KronosPerformance
I sent you a PM with a link. If anyone else needs a link let me know.
KronosPerformance is offline   Reply With Quote
Old 07-27-2012, 01:11 PM   #145
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
Originally Posted by empower-auto View Post
While you're here, quick inquiry:
1. Is Molly cute?
2. Is that harassment?
1. Yes
2. Depends
My idle is still a yo-yo even with the pulley installed
EDIT: I didn't expect the pulley to solve this either. I'm just waiting for a CEL to come on if it does. If it doesn't & I have a problem in the future, it's been documented 1900 miles into ownership.
The pulley will not fix this problem. I have experienced this on my car and there isn't one thing that causes it. I have done it with AC on or off. The good news is, that I can log lots of parameters and firgure it out. What I suspect it is, is an over compensation from the idle control stuff. The other factor is the Port injection and Direct injection switch on and off at idle sometimes, which that could be it as well. I suspect a tune will fix this, but I have NEVER had mine die, or actually stumble. The most i have seen is the RPM drop to 500-400 and then it comes back up.
I mentioned this to my dealer 2 days after I got the car. Making sure that it was noted in the system. The idea being that after I get 3000 miles I can take it in and see if they have a fix.
PERRIN_Jeff is offline   Reply With Quote
Old 07-28-2012, 09:28 AM   #146
lopro25
lopro25's Avatar
Drives: Hot Lava FR-S
FYI, I emailed Chris about my 2nd-batch crank pulley order and he assured me it has been shipped.
Also, he was very appreciative of our support on this forum and thanks us for caring about his company. He very much looks forward to being back on here after the 1-month ban.
lopro25 is offline   Reply With Quote
Old 07-28-2012, 10:34 AM   #147
empower-auto
Kouki-Monster
empower-auto's Avatar
I just got mine yesterday. I pick the car up this morning. woo!
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-05-2012, 12:09 PM   #148
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
While this part is on my list for sure my question has always been about why Subaru hasn't made this a light part from the start on their performance cars?
Making this a separate part for the WRX/STI/BRZ would seem to make sense because it would add that much more responsiveness to their performance line up. Is it just a cost issue?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
Old 08-06-2012, 08:04 PM   #149
wu_dot_com
Drives: accord
for those that have idleing problem, have you tried disconnectig your battery?
i did it, and i think it erase the flash memory with OEM setting and self adjust it to the new pulley setting.
wu_dot_com is offline   Reply With Quote
Old 08-06-2012, 08:39 PM   #150
mike2100
mike2100's Avatar
Drives: 23 BRZ
Which sensor's reading do you suppose would change due to a decrease in rotating mass?
mike2100 is offline   Reply With Quote
Old 08-06-2012, 08:47 PM   #151
wu_dot_com
Drives: accord
to be honest, i am not quite sure since i was not able to get my dataloger going.
but. i did get a CEL when i first installed the pulley after the light flywheel installed. when i disconnect the battery, the CEL went way and the idle correct it self.
Old 08-06-2012, 08:49 PM   #152
mike2100
mike2100's Avatar
Drives: 23 BRZ
I got a check engine light too, but I assumed it was because I forgot to plug the MAF back in before I started the car. So I shut it down and plugged it back in and after 3 drive cycles the light turned off.
Did you happen to forget to plug your MAF back in before starting the car?
Old 08-07-2012, 12:33 AM   #153
hotaka
Drives: na
Question. There are little plastic covers that cover the alternator and compressor pulleys. What's the purpose? Are those important? Can they be removed for weight reduction (though its not much)?
hotaka is offline   Reply With Quote
Old 08-07-2012, 12:55 AM   #154
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Almost positive it's just a safety/protection thing with those covers. At first thought I figured it was so you could work on the engine without getting the belts all dirty.. or yourself hurt on them while it's running.
eriktherod is offline   Reply With Quote
Search this Thread:
Advanced Search
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
pulley installed issue Sall Issues | Warranty | Recalls / TSB 31 08-14-2012 11:36 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
Perrin Lightweight Crank Pulley for the BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 07-07-2012 10:24 PM
