Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
01-12-2020, 02:30 AM | #15 |
Drives: 2013 FRS
the thing I don't get is how you're supposed to access the end links with the car on the ground...?
Do you lock the steering wheel to one side and reach in and do it? Then vice versa for the other side? |
The Following User Says Thank You to Stomachbuzz For This Useful Post: | norcalpb (01-12-2020) |
01-12-2020, 06:04 AM | #16 |
01-12-2020, 10:59 AM | #17 |
Drives: 2013 FRS
I'm still confused on this issue since [from my understanding and visual intuition of the sway bar] the length of the endlink doesn't affect preload. Preload comes from each side being at a different position. So if one endlink is 10" and the other one is 8.5", that would create a preload on the swaybar. This would mimic one wheel being 'higher' than the other through a corner.
But if they are both at the same position, I don't see how that creates any preload. What it does do is change the orientation of the swaybar with respect to the strut, which I'm sure is necessary for lowering the car. In other words, if you just set both endlinks to the same length, no matter the length, then you wouldn't have preload. I assume it might create binding if the geometry isn't correct though. But maybe I'm wrong |
01-12-2020, 11:13 AM | #18 | |
Drives: Crapcan
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
01-12-2020, 11:57 AM | #19 | |
Drives: 2013 FRS
My car isn't yet lowered. |
01-12-2020, 03:49 PM | #20 | |
Drives: 17 BRZ Series.Yellow
@Stomachbuzz you're mostly right, but you need to take vehicle weight into account. Sent from my Pixel 3 using Tapatalk |
The Following User Says Thank You to Nuts & Bolts Performance For This Useful Post: | whataboutbob (01-16-2020), wparsons (01-13-2020) |
01-16-2020, 10:57 PM | #21 |
AutoX-10/10ths every run
^^^ This. The weight load from the chassis on the suspension is not perfectly even. Because of this you will get different loads on the suspension at each corner, resulting in different amounts of static compression of your suspension. This leads to the need to adjust each of the endlinks individually with the car on the ground.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
01-17-2020, 01:36 PM | #22 |
Drives: 2013 FRS
Okay, so how do you prepare the swaybar to be flat?
The eyelet where the endlink connects is at the end of a curved portion, not a flat part of the arm. My best guess would be to make sure the endlink is perfectly vertical, to maximize articulation. Picture taken from: https://www.suspension.com/blog/how-...-sway-bar-brz/ |
01-17-2020, 01:57 PM | #23 | |
Edit: oops, didn’t see you pulled that image from online. Last edited by norcalpb; 01-17-2020 at 04:30 PM. |
01-20-2020, 05:25 PM | #24 |
Get a second jack or use the scissor jack and lift up rotor and suspension to the same height it would be if the wheel was on. It works. Easier than ramps and trying to tighten them from under the car.
01-21-2020, 12:29 PM | #25 | |
Drives: 2013 FRS
I figured doing it with wheels on & car on ground was ridiculous. So I just put a jack until the outer part of the control arm. |
Similar Threads | ||||
Factory sway bar endlinks | Joesurf79 | Brakes, Suspension, Chassis | 1 | 11-28-2018 03:40 PM |
WTB sway bar endlinks | dattran86 | Canada Classifieds | 4 | 03-21-2018 10:27 AM |
F/S:Perrin sway bar endlinks | Trac Toy | Canada Classifieds | 0 | 11-22-2016 09:23 PM |
WTB: Rear sway end links or sway bar with endlinks | JoeBoxer | Want-To-Buy Requests | 1 | 08-03-2015 01:20 PM |
Front Sway Bar endlinks | D1cker | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-30-2012 04:14 PM |
