Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
01-21-2014, 12:42 PM | #29 |
Drives: 2013 Scion FRS 10 Series
I'm having the same issue, running catless UEL header, Ecutek tune, my CEL light came on with cruise control being used. CEL does disable the cruise control. My code was P0137, low voltage secondary o2.
01-21-2014, 01:05 PM | #30 |
You need to have the secondary O2 disabled through Ecutek. The only one that should be used is the primary.
01-21-2014, 01:11 PM | #31 |
Thupercharged
Just an update, ecutek tune can disable the dtc if you have no secondary o2 sensor, just ask your tuner
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
The Following User Says Thank You to DJCarbine For This Useful Post: | post_break (04-22-2014) |
04-10-2015, 08:49 PM | #32 | |
Drives: 2013 scion FRS
I had the same issue
I had the same issue i had some dc sports headers installed and nothing happened i drove for like a month and then i was on the highway and ia had my cruise control on and it shut down and the check engine light came on.I took the car to the dealer and they said it was bc of the o2 sensor so i heard that by installing a spacer on it you can fix the problem. |
Similar Threads | ||||
Cruise control malfunction | totally | Issues | Warranty | Recalls / TSB | 20 | 02-26-2018 09:13 PM |
Cruise control temporarily disabled? | DarrenDriven | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 06-29-2016 08:35 PM |
Cruise Control 'set' light | LeftFootBrake | Issues | Warranty | Recalls / TSB | 28 | 11-27-2015 08:38 AM |
Cruise control | notout86 | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 05-13-2013 02:01 AM |
Aftermarket cruise control... anyone? | Yamajee | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 05-10-2013 06:18 AM |
