12-15-2012, 11:36 PM | #99 |
Drives: 2013 FR-S Blue MT
I still don't think NOACK is terribly important unless you have issues with intake valve deposits or significant oil consumption as you are referring to. The NOACK test is at 150C which is significantly hotter than operating temperature. I would honestly be surprised if oil consumption was significantly impacted by NOACK unless used in extreme enviroments like racing.
I believe HTHS is rated in cP or cSt rather than percent, but I get what you are saying. I have yet to see a reason to run a thicker oil (whether it be 100C viscosity or HTHS) in a unmodified FA20. Even the UOA's with significant shearing seem to have low wear. I used to own a 2005 Subaru Legacy GT and ran M1 5W-30 for the first 60K and Rotella 5W40 for the next 60K. It never burned enough oil between changes every 3500 miles to even bother topping it up. I sold it at 120K with the original engine and turbo but did have to get the clutch replaced due to a noisy throwout bearing. |
12-16-2012, 12:39 AM | #100 |
Drives: Firestorm FR-S
Getting my first oil change next week. The dealer gives you the 3 free of course but I just can't wait 7500 miles. Top will be every 3500.
12-17-2012, 02:19 PM | #101 | |
My FXT burned through one quart of Mobil1 0W-40 (spins at 3,500 rpm's at 80 mph) on a spring trip from NJ to SC. UOA just posted at bitog. -Dennis Last edited by bluesubie; 12-17-2012 at 04:45 PM. |
12-17-2012, 02:39 PM | #102 | |
Drives: Scion FRS Ht Lva(AT)
Dennis, I struggle with this comment in isolation. Whether something shears or not is dependent on its shear stability, not its VI. VI only tells you about the rate of change of kinematic viscosity with temperature. If you only had a VI value it would not tell you much about how thin an oil was at any particular temperature. The last time I was aware, low temperature CCS and MRV viscosities were the most relevent characteristics to low temperature performance. |
12-17-2012, 04:40 PM | #103 | ||
I'm not a chemist and I don't play one on TV. A high VI does tell you about the rate of change of kinematic viscosity and a higher VI usually, but not always, gives you an indication how light the oil is in freezing temps but isn't a measure of actual KV. MRV viscosities are useful at what? -35 or -40C? And MRV doesn't do you any good if you do not know what it is since it's less common to be listed on a PDS. I'll just go with the ASTM definition of VI to avoid confusion: Quote:
-Dennis Last edited by bluesubie; 12-17-2012 at 05:23 PM. |
12-17-2012, 09:21 PM | #104 |
I towed a 2500+ lb enclosed motorcycle trailer (loaded) many times, some of which were 4+ hour trips each way and it made no difference to oil consumption. Is that your definition of conservative?
I don't think its safe to assume that every car burns oil equally. I'm sure there are FA20's out there that burn lots of oil, but there many that don't burn any noticeable amount. What is your take on why the FB20's tend to burn oil? Rings, oil too thin, valves? I also owned a 2000 Legacy GT Wagon with the EJ25D, bought it used with like 120K miles. It had horrible piston slap and burned copious amounts of oil. Oil weight seemed to make little difference in the piston slap or consumption rate. |
12-17-2012, 10:13 PM | #105 | |
12-18-2012, 02:06 PM | #106 | |
-Dennis |
12-18-2012, 05:43 PM | #107 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
In the Jetta 1.8T I flipped between PP 5/40 and Castrol Syn 5/40 with good results. |
12-19-2012, 12:18 AM | #108 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
I've been running Pennzoil Ultra 5w20 since my first oil change at 3000 miles. I'm currently at 7200 or so with no oil consumption. On the dipstick the oil is still an amber color.
At 10k or 11k I will change the oil again and send it in for a UOA and see what we find. |
12-19-2012, 10:46 AM | #109 |
12-19-2012, 09:35 PM | #110 | |
Drives: 2007 WRX
Mobil 1 is also heavier at operating temp (HTHS of 2.7 vs 2.6), so it will also handle higher temperatures better. Canadian summer doesn't really qualify as hot, though, so PP would likely be fine. The real determining factor on high temps is usage (track), not air temp though it does play a substantial role. The real question is which oil performs better 4,000 miles into the OCI. It's quite possible that PP handles fuel dilution better than M1 and would therefore maintain it's performance better than M1. The previous UOA showing a 375*F flashpoint points to some possibility of dilution in these cars. Without more UOA data we just don't know. |
The Following User Says Thank You to gpshumway For This Useful Post: | bluesubie (12-20-2012) |
12-19-2012, 09:45 PM | #111 | |
Drives: 2007 WRX
Dennis- Remember that Subie SM oil I bought a few months ago at my local dealer? (BITOG Link) Well, I just got a UOA back with it (in my Honda) and the moly levels are dramatically lower than the previous fill of the Subie SM. Like 280ppm instead of 560. I didn't do a KV40 on it, so we don't know the VI, but it's still in the car and I will do a KV40 when I drain it in March or April with ~6,500 miles on it. Safest to just go with the Mazda oil at this point if you want the high VI and high moly. I'll see if I have time tomorrow to post the UOA over on BITOG. |
12-20-2012, 09:58 AM | #112 | |
When the Subaru oil first came out they did not even label it with the API or ILSAC spec! You can probably even find pics of the old bottles on line. When I emailed SoA in September of 2011 to ask when the oils would be switching to SN/GF5, they didn't have any info. Any oil made from October 2011 onwards that gets the API Starburst must meet SN/GF5. Maybe your oil wasn't blended at the lab correctly. You can always email Idemitsu for information. -Dennis |
Similar Threads | ||||
DIY BRZ / FR-S Oil Change | RallySport Direct | DIY (Do-It-Yourself) Guides | 169 | 09-01-2018 02:42 AM |
First Oil Change | Jehuty77 | CANADA | 14 | 08-09-2012 11:54 PM |
When to do your first oil change, and why... | MrBodyMassage | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 14 | 07-17-2012 07:43 PM |
Do you change your own oil? If so, why? | SteelReign | Other Vehicles & General Automotive Discussions | 77 | 04-16-2012 10:12 AM |
