go_a_way1
Old 09-12-2013, 04:06 AM   #1793
wahsaihin
Drives: 2013 Subaru BRZ Sport-Tech
hi guys. shopping for winter tires. found used ones that come with the subaru wrx 16 inch rims (not sure which year) with 205/55/16 tires. just want to make sure these will be a direct fit and bolt on. my car is fully stock. thanks.
http:// http://calgary.kijiji.ca/c-cars-vehicles-auto-parts-tires-tires-rims-Michelin-Primacy-Alpin-Winter-Tires-205-55R16-with-Rims-W0QQAdIdZ522732292
wahsaihin is offline   Reply With Quote
Old 09-12-2013, 09:03 AM   #1794
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
It should all fit well, tire size is great for winters actually, and I know some local guys running Subaru 16" wheels without issue. I would verify and test fit (on the front) to make sure it is the 5x100 bolt pattern wheels and that they clear the brakes.
Slick is offline   Reply With Quote
Old 09-12-2013, 12:41 PM   #1795
wahsaihin
Thanks Slick. Anyone else? I'm going to look at the wheels today and am prepared to buy them on the spot if they are as described. Just want to know if anyone knows if these will fit for sure. Thanks.
Old 09-12-2013, 12:44 PM   #1796
Slick
Slick's Avatar
Ask him what year/model his WRX is. From there, you should be able to confirm what bolt pattern and offset.
Or if you are going to look at them, bring your jack and pull one of your wheels to try.
Old 09-12-2013, 12:46 PM   #1797
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
18x11 +20 on all 4 corners with a rocket bunny kit? What type of modifications would have to be done to make wheels that wide fit up front?
CodyFRS is offline   Reply With Quote
Old 09-12-2013, 12:55 PM   #1798
Slick
Slick's Avatar
Same as these?
http://www.ebay.com/itm/68761-SUBARU...-/151109335477
http://www.ebay.com/itm/SUBARU-IMPRE...-/171095986510
http://www.ebay.com/itm/SUBARU-IMPRE...-/111004332281
5x100 +55 offset, good to go.
The Following User Says Thank You to Slick For This Useful Post:
wahsaihin (09-12-2013)
Old 09-12-2013, 01:52 PM   #1799
wahsaihin
those are the ones. Thanks Slick!
Old 09-13-2013, 02:05 AM   #1800
HATED1
HATED1's Avatar
Drives: 86
Originally Posted by HATED1 View Post
Does anyone know if i can fit 235/40/17 all around with no issues with the 17x9+30 Rota Torques?
Or should i go with a 225/40/17 to be safe?
BTW i have the SPC rear camber arms and BC coils going on as well.
If anyone can help, I would greatly appreciate it!
Hey guys, can anyone else confirm that this will fit with little to no issue? I appreciate the previous answer but just want to make sure! gonna buy the tires in a couple days.
HATED1 is offline   Reply With Quote
Old 09-13-2013, 11:36 AM   #1801
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Did you search the fitment chart? That setup will fit but I can't confirm how much negative camber depending on how low you go. I had no issues with 235/45 on a wheel 2mm lower offset than this. Both tires you're talking about are shorter, so even less issue.
If you go with 225, stick with 45 sidewall. 235 can go 40/45, neither one is dead on, but 245/40 is about the same height as stock.
Hell, TiC had 9.5" wide +30s on their car, with 265s I believe. IIRC, they even had this on stock suspension before going to coilovers.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following User Says Thank You to 2point0 For This Useful Post:
HATED1 (09-13-2013)
Old 09-13-2013, 12:28 PM   #1802
rip curl
Drives: 13 BRZ
I'm looking at a set of 2000 Impreza 2.5RS rims for a winter setup. I believe the rim size is 16x7 with a 45mm offset or 53mm offset. Would these work on the BRZ? What tire size is receommended?
rip curl is offline   Reply With Quote
Old 09-13-2013, 12:49 PM   #1803
Slick
Slick's Avatar
Look further up the page for pretty much the same setup.
205/55R16 is the ideal tire, very close to OEM diameter. Those rims should work fine as the 2.5RS was on 5x100 bolt pattern.
Old 09-20-2013, 01:29 AM   #1804
Perry
Drives: 86 Raven
Hello just want to ask im planning to go 17x9 +42 offset lowered on H&R SUPER SPORT. Which tires should i use? i mean what specs of tires can i use? thanks
Perry is offline   Reply With Quote
Old 09-20-2013, 10:08 AM   #1805
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
215/45 stock
225/45 little taller
235/40 little shorter
245/40 close to stock diameter
255/40 little taller
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
The Following User Says Thank You to ill86 For This Useful Post:
Perry (09-20-2013)
Old 09-20-2013, 03:09 PM   #1806
Slick
Slick's Avatar
Good info on tires ill86.
But OP you may want to check this thread. That offset is extremely tight, especially with a drop.
http://www.ft86club.com/forums/showthread.php?t=46733
The Following 2 Users Say Thank You to Slick For This Useful Post:
ill86 (09-20-2013), Perry (09-20-2013)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
